Rotor Comparison: OTTP Hardcore vs. SS/TC
Old Apr 29, 2009 | 12:12 PM
Maven's Avatar
Originally Posted by rocketrex
so any news on these?? for the sc guys??
They are coming real soon..........
Originally Posted by elecblue06
any plans to produce things like this for the 2.2 4 lug setup ? theres a company working on a rear brake conversion and are using a 9.3" solid disks for the rear due to using a vented rear would cause it to be just slightly bigger then the front rotors..
if OTT put together a hardcore brake package for the 4 lugs using the astra brakes like you outlined it would open up the possibilities for vented rears that are 10.1 " sorry for the jacking .. i'm just curious
I am working on it
Old Apr 29, 2009 | 12:40 PM
red06SC's Avatar
so....how about those time attack rotors?
Old Apr 29, 2009 | 04:04 PM
Maven's Avatar
They are coming soon.....I think they are in machining right now....or soon
Old Apr 29, 2009 | 04:40 PM
HunterKiller89's Avatar
Originally Posted by 08RYNePh
Ok, so I see the weight difference, and I've read all the other posts but I fail to see the most important thing - which brakes have the better stopping ability (shorter stopping distance, consistency, etc.)? All that's been said thus far seems like speculation to me.
brakes dont reduce stopping distance, tires do
Old Apr 29, 2009 | 06:16 PM
Josh@ottp's Avatar
both brakes and tires can reduce stopping distance.
Old Apr 29, 2009 | 10:01 PM
rocketrex's Avatar
thanks maven i was like "ah **** i havent herd anything about this" so i just wanted to make sure!!!
Old Apr 30, 2009 | 06:38 AM
got my moneys waiting
Old Apr 30, 2009 | 09:05 AM
rocketrex's Avatar
how do breaks not stop a car as well? fail
Old Apr 30, 2009 | 11:36 AM
RocketPunch's Avatar
The TC set-up just need a lighter rotor, but I can see for non TC cars the OTTP is a good way to go as an upgrade. Combined with a good light wheel, the amount of unsprung shaved would be substantial over stock set-up.
Old Apr 30, 2009 | 01:14 PM
only if your experiencing brake fade.
unless your on the autocross, you will not reduce brake distances at all with any brake upgrades when using the same tire.
you should learn before you call someone out. its usually embarrassing when you find out they were right and you were wrong
Last edited by HunterKiller89; Apr 30, 2009 at 01:14 PM. Reason: Automerged Doublepost
Old Apr 30, 2009 | 01:52 PM
  #36
elecblue06's Avatar
umm .. what ... assuming the tire can hold the road while braking upgrading the brakes will effect braking distance.. if the tire skids it's not holding the road.. and not effectively making use of the brakes ...
Old Apr 30, 2009 | 03:26 PM
  #37
right...but a brake package will always be able to grip a caliper better than a tire can grip the road. Thats why when braking, the caliper stops the rotor from spinning completely, but the tire keeps sliding on the road, instead of the other way around. a stock base model 2.2 can lock their brakes with ease...therefore brake force is NOT the limiting factor in stopping, but tire grip is.
if you want a better explanation, go read i think the 2nd page of mavens thread called "sneak peek: time attack brake" or w/e he called it.
Old Apr 30, 2009 | 03:30 PM
  #38
Omnigear's Avatar
the tire have a rating to how much it can hug the road
so even if you put 747 carbon fiber brakes its
not goin to be effective.
Jan 12, 2016 12:01 AM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
