shaking steering wheel... help me diagnose?
Old Jun 7, 2012 | 09:50 AM
Dart_SI's Avatar
Angry shaking steering wheel... help me diagnose?
Alright, I have a weird inconsistent steering wheel shake.
It shakes around 55-75 and is the worst at 65. Above 75 it goes away and below 55 its not there.
Nothing vibrates or clunks when I turn. Now, the weird part. Sometimes ill go on a drive and get no shaking at all... weird.
Also, yesterday it was shaking pretty good, then when I took a right turn on an onramp, it stopped shaking. For a half hour at least.
Its really starting to annoy me because its a good shake. Lol.
Rotors and pads were replaced 2 days ago. No effect.
Old Jun 7, 2012 | 09:53 AM
Supercharged Guy's Avatar
Possibly need the tires re balanced...
I know mine was shaking really bad between 55 and like 70 like yours is doing
I got my tires re balanced and it went away
Old Jun 7, 2012 | 10:14 AM
Dart_SI's Avatar
Im actually going to rotate them too. Eff it. Lol.
Old Jun 7, 2012 | 10:24 AM
K-Train04RL's Avatar
Check ur front end over for play
Old Jun 7, 2012 | 10:28 AM
willie_panic's Avatar
I don't know about these car's but your steering system could be loose. I know that's a generel catch all, but joints wear out and so forth. Maybe something to look into.
Old Jun 7, 2012 | 10:34 AM
Dart_SI's Avatar
True. But its a 2010 with 40k mile. 80% of those miles are highway too. I commute to work. Ill check it all over tho. Possibly upgrade some things too.
Old Jun 7, 2012 | 10:41 AM
If the roads are the same where you are as they are for me then I wouldn't be surprised. I got my wheels aligned 3 months later they were off again. Crappy roads, even the highways, and freaking road work all the time.
Old Jun 7, 2012 | 10:43 AM
1AJeremyD's Avatar
I'm thinking it will most likely boil down to a tire issue in the front. If they are new, i would have them road forced and see what pops up. The hunter and snap on machines are really good at knocking them out of the equation.
Old Jun 7, 2012 | 10:56 AM
nobody2u's Avatar
Tire balance, bent rim. Common problems perhaps.
Old Jun 7, 2012 | 10:58 AM
Dart_SI's Avatar
I've been working on fort riley for 3 years. Since day 1 there's still TONS or road construction so u could be right on.
Old Jun 7, 2012 | 11:50 AM
noorj's Avatar
Guarantee an alignment will fix it. I had about the same problem a year ago. Everyone will come up with crazy ideas for the wheel shake. Find the cheapest alignment place you can and let us know how it goes.
Old Jun 7, 2012 | 12:01 PM
unless you have to get the back tires alligned, freaking pricy whereever you go. THank you chevy for that!
Old Jun 7, 2012 | 12:55 PM
2005Noir's Avatar
Mine did the same thing, got wheels balanced, tires rotated and fixed a rear caliper that wouldn't open and close correctly and was catching on the rotor. One of those things fixed it. Haha
Old Jun 7, 2012 | 02:35 PM
Dart_SI's Avatar
Lol. I got an alignment 5 days ago so I know its not that. I know my rear wheels are out pf balance too thanks to my fender taking off a few chunks of tire. Next up is balance and rotation. Lol.
Old Jun 7, 2012 | 02:43 PM
cubaniche's Avatar
Yeah man, if you havent balanced them and rotated yet, but youve done everything else and the problem persists then.....balance and rotate should fix
Old Jun 7, 2012 | 02:52 PM
noorj's Avatar
Lets see the print out, I bet it isn't in spec.
Old Jun 7, 2012 | 02:55 PM
TommyP's Avatar
AWD > FWD
Could possibly be a broken belt in the tire too
Old Jun 7, 2012 | 02:58 PM
rdskns432's Avatar
Same problem with mine, but mine also shakes when I give it gas at any mph, an then shakes on its own betwwe 50 and 75. Had tires balanced an checked. Found out I had a lot of play in my left axle so I ned too have them replaced.
Old Jun 7, 2012 | 03:16 PM
Dart_SI's Avatar
How'd they figure out it was the axles? Any way to check them?
Old Jun 7, 2012 | 03:31 PM
kikal8's Avatar
Its going to be a balance. Balance issues r like 90% of shaking issues. And when its only at certain speeds like ur saying that leads me to believe its a balance even more.
Old Jun 7, 2012 | 03:40 PM
Eurasianman's Avatar
I have the same issue and my tires were just balanced. I'm wondering if the people didn't balance the tires right or if it's something else. Some days, it vibrates horribly around 60MPH-75MPH. Other days, not so much.
Old Jun 7, 2012 | 03:43 PM
rdskns432's Avatar
Put it up on lift and moved the tire back and forth. Had a lot of play and made a funny cracking noise. Urs is prob just balance though. Whenever I give it gas it will shack a little and when I shift it will. So it all kinda leads too my axles being bad I assume
Old Jun 7, 2012 | 04:27 PM
Dart_SI's Avatar
Ah I see. Luckily I don't have that issue. So it probably really is a balancing issue.
Old Jun 14, 2012 | 12:58 PM
Well, took my car in yesterday to get the front wheel rebalanced. Turned out one of the wheels wasn't balancing right due to the technician leaving the hub centric ring off (the ring was still on the car ). Now that the wheels have been re-balanced, I don't notice any more shaking. Gotta be honest, when I saw them trying to balance my wheel, I thought I had bent/warped the rim. Was about to get real pissed. Luckily, the other technician noticed that the hub centric ring was missing.
Old Jun 14, 2012 | 06:41 PM
Jboss's Avatar
hahaha that means shitty techs and shitty work, would recommend you bring you car there anymore.
if they're stupid enough to forget the eccentric ring then they're stupid enough to forget about tightening that wheel nut or head bolt ect...
