Shim Kit
Old May 9, 2012 | 03:35 PM
znew's Avatar
Shim Kit
Anyone have expereince installing a shim kit on the rear or our cars. I need a shim to fix my camber in the rear. I have a 2.2l ls
Old May 9, 2012 | 10:09 PM
me6894's Avatar
How far off is it? Chances are something is bent... I wouldn't recommend shims.
Old May 9, 2012 | 10:23 PM
Sharkey's Avatar
shimming is a normal thing if its just out a little bit. if its way out of wack then yes, something is bent and replacing the axle is the way to go.
Old May 9, 2012 | 10:26 PM
znew's Avatar
no its nothing drastic just 1 degree out
Old May 10, 2012 | 10:21 AM
scottherbert's Avatar
I had the rear of my 09 SS shimmed out to -1.55 on both sides (that's the most negative I can 'legally' run in SCCA autocross).
The shop did a great job (we also carefully shimmed the brake calipers to get the same negative as the hub/rotor) and I've had no problelms.
Scott
Old May 16, 2012 | 10:32 PM
znew's Avatar
well the passenger side is good the driver side needs a shim i guess to fix the -1 degree the toe is out i just dont know where to go to get it done
Old May 28, 2012 | 10:33 PM
znew's Avatar
Where do i go to get a shim installed. I don't have any of the tools necessary out here where I am this summer
Old May 28, 2012 | 10:35 PM
Sunburst_SS's Avatar
we do them at the dealership all the time.....any good alignment shop should be able to handle it for you
Old May 28, 2012 | 10:37 PM
znew's Avatar
im living in kitty hawk for the summer so ill hit up the dealership here at some point. I just got an ailgnment back home in charlotte so I dont need another one I know what degree the toe is off.
Old May 28, 2012 | 10:39 PM
well I doubt a place will just slap a shim on and not have it on the alignment rack.......they will need to see what shim they need, and make sure it is spec afterward.
Old May 28, 2012 | 10:43 PM
znew's Avatar
then im in trouble cause with my coils i cant get on a lift lol. It has to be a in ground lift and I think the closest one is probably somewhere in virginia
Old May 28, 2012 | 10:45 PM
we use some long boards to act as a ramp to get low cars on the rack.......if I can get a lowered z06 on the rack, I'm sure your cobalt can make it lol
Old May 28, 2012 | 10:47 PM
znew's Avatar
Its a lot closer than you think. Im tucking tire the entire way around im lower than a stock z06 by a long shot. So a lowered one would be close to me
Old May 28, 2012 | 10:48 PM
znew's Avatar
What dealership do you work at? ill wait to do it when im back in town then.
Old May 28, 2012 | 10:49 PM
MastaShaKe_88's Avatar
go back to firestone!
Old May 28, 2012 | 10:50 PM
znew's Avatar
they wouldnt do it while i was there.
Old May 28, 2012 | 10:54 PM
PM me for info
Old May 28, 2012 | 10:58 PM
Synergy1415P3's Avatar
Use 3 pieces of 2x4 for each wheel. One as a first step, then 2 after that so you can get up high enough.
Like this for each wheel:
Wheel
dennis69
Oct 20, 2015 04:49 PM
thewafflesareburnt
Sep 30, 2015 02:29 AM
Sep 28, 2015 12:51 PM
metroplex
Sep 27, 2015 07:48 AM
