side to side shaking while under acceleration
Old Sep 17, 2013 | 07:55 AM
blueLNFftw's Avatar
Originally Posted by dcrep06
hmmm, well i have no clicking noises so its not the axles im at a loss right now for my wheel shaking problem maybe i should try and rotate the tires then. see if that helps any. kinda need to do that anyway. lol.
Have you looked at the U Joints in your intermediate steering shaft?
Old Sep 17, 2013 | 08:18 AM
wouldn't be a bad place to start man. jack up the car and try shaking the wheels from side to side if they do it could be hubs
Old Sep 17, 2013 | 08:30 AM
blueLNFftw's Avatar
does it do this?
Old Sep 17, 2013 | 10:56 AM
does what do what?
Old Sep 17, 2013 | 11:02 AM
blueLNFftw's Avatar
does what do what?
Watch the video, about 2/3 of the way through.
Look at the steering wheel under braking.
Listen closely too.
PS.
You sold me that molly I can't seem to find.
Old Sep 17, 2013 | 11:04 AM
oh i didn't know it was a video
mine was not doing anything quite like that :/
Old Sep 17, 2013 | 12:59 PM
dcrep06's Avatar
its not during braking so i know its not the rotors. its only while accelerating, the harder i pull the more it shakes. but yea, i think i will check the hubs too.
Old Sep 17, 2013 | 01:08 PM
blueLNFftw's Avatar
Mine isnt the brakes either, its the intermediate steering shaft joints
Old Sep 17, 2013 | 02:43 PM
dcrep06's Avatar
you already fix yours? how did u figure it to be that?
Old Oct 7, 2013 | 10:19 PM
mine shakes at above 60 but not always consistent. i can let go of the wheel and it just shakes back and forth.
it seems to shake more depending on what part of the freeway im on, i got a new job last month and im doing 80miles a day so im noticing more things now
axles click and such, car still pulls if i need to get the blood pumping
the alignment is probably off too
all them bumps in the road
Old Oct 7, 2013 | 10:24 PM
  #36
yellowsupercharged06's Avatar
Mine does the exact same thing ... I mean exactly lol it shakes but drives straight still wen u let go lol. And it isnt always the same idk what it is.
If you figure out the issue pm me please and let me know. If i fig it out ill let ya know
Any ideas ?
Old Oct 7, 2013 | 10:43 PM
  #37
Any ideas ?
it feels like it could be something in the steering column but i wouldnt know, im at 73,xxx miles
it looks funny all shaking hahaha
Old Oct 10, 2013 | 02:48 PM
  #38
hahaa yea im thinking maybe some new CABs and an alignment lol
Old Oct 10, 2013 | 03:10 PM
  #39
well i'll tell ya guys what. new axles, struts, strut mounts, CAB's and an alignment and the shaking and clicking is gone.
i think the clicking and shaking stopped when i did the axle. still shook a bit though until car was aligned after the struts.
its a LOT better now.
however, over the last few months i've been hearing a thump-thump-thump as im cruising around speeds 40 or under... almost like when your brakes are warped.
i don't think its the brakes because it stops nice and smooth, nor does the sound change/go away/get louder when i'm on or off the brakes.
also doesn't matter if i'm on or off the gas, in gear, neutral, clutch in or out...
hubs?
Old Oct 10, 2013 | 03:35 PM
  #40
i few weeks ago my lower perch came loose and it allowed the endlink to move which hit the wheel at like 1mph haha so that could of thrown the alignment off a little
i feel like it started shaking after that happened too but my axles or maybe a vac leak is killing me in traffic. ill be in 1st cruising and it will buck out of nowhere, like hopping
it does it in pretty much any gear if im trying to hold a constant speed. i noticed that after i did the hub swap i think.
i mean getting some new parts will be good and probably fix some of this nonsense
thump thump, rear shocks? i think my rear right is going but idk
Old Oct 10, 2013 | 03:39 PM
  #41
i did a hub swap recently as well lol ... hmmmmmmm
my car bucks like a bronco but i just ride that bitch
Old Oct 10, 2013 | 03:53 PM
  #42
any better with new hubs?
Old Oct 10, 2013 | 04:11 PM
  #43
thats when i noticed it lol .... but i cant say its due to the new hubs
Old Oct 10, 2013 | 04:18 PM
  #44
yea just give it some gas and its fine
Old Oct 12, 2013 | 04:46 PM
  #45
dcrep06's Avatar
yea im thinking i need some new CABs, i was talking to powell about it. he seems to think its the CABs since its usually just when im on the throttle. my struts and springs need some changing too, 92k and counting on all original parts. powell is gonna make some money off me soon lol.
Old Oct 21, 2013 | 10:41 PM
  #46
Carlosparodi2004's Avatar
I have the same problem but it shakes side to side when I lower the speed. Any idea?
Old Oct 22, 2013 | 03:23 PM
  #47
dcrep06's Avatar
braking^^??
Old Oct 22, 2013 | 04:44 PM
  #48
im gonna get some axles on Wed. and i think my upstrem o2 sensor needs swapping.
when in stop & go traffic ill let it coast in neutral and the rpms will go up and down(1k-1.5k~). its not new just figured it was my dirty TB, which before cleaning the rpms would do that but (1k-down)
idk if it could be due to some of the bolts on the header not being torqued down enough causing the sensor to read funny.
Old Oct 22, 2013 | 04:54 PM
  #49
Yes
Old Oct 22, 2013 | 05:19 PM
  #50
braking^^??
Yes
