side to side shaking while under acceleration
Old Sep 12, 2013 | 12:37 PM
i think i mayy know what is causing this, but never hurts to check...
first off, i think my drivers side axle is shot; it has leaked a lot of its grease out and its everywhere.
anyway, the other day i replaced my drivers side control arm bushing and my intermediate shaft (from behind the steering wheel through the firewall)
it was all good after that, but the next day i noticed whenever i'm on the gas, the car is shaking badly, and it seems to make the car shake from side to side. you can feel it in the steering wheel, even.
i checked my lugnuts (always a first) they are good and tight. all other suspension parts seems good and tight.
soo... axle? think i can just inject a shitton of grease into it and call it a day? i gotta drive my car to indiana this weekend
Old Sep 12, 2013 | 12:48 PM
buildmeanempire's Avatar
I'm racking my brain trying to think what it could be but it may just end up being the axle. I had a problem like this with an old truck. I never replaced the axle but always pumped the cv boot with grease.
Old Sep 12, 2013 | 12:53 PM
blueLNFftw's Avatar
Axle.
Pull it and have it rebuilt.
Its stupid easy and costs like $20.00.
They will replace the boots and grease them up.
Old Sep 12, 2013 | 01:00 PM
or maybes i could pull it and rebuild it
i do have an extra axle, maybe ill just get that rebuilt (what, take it to some shop i guess?) and throw it in tomorrow
Old Sep 12, 2013 | 01:03 PM
blueLNFftw's Avatar
Yea. Just find a drive shaft shop, its usually while you wait.
I had both of my OEM ones done because they were clicking and a fucked the boot on one doing the cluth. Cost me $40.00 and I brought the guys at the shop a dozen of my family's donuts.
Id rather have rebuilt OEM then third party aftermarket (which I tried 4 different ones from parts stores and none even fit).
Old Sep 12, 2013 | 01:12 PM
Staged07SS's Avatar
Administrator
Administrator
Go to Napa and get a new axle (s).
They are like $60 and a little bit beefier than stock. I have them on my car, and they are super nice quality.
Frig messing with rebuilding an axle. Messy job, and tedious getting the old boots off and new boots on.
Old Sep 12, 2013 | 01:45 PM
do you think those napa ones are the same as the zzp stg1's? because zzp's are advertised to be 1mm thicker than stock, and that's the extra one that i have laying on the side. i'm just a little strapped for cash right now is all
Old Sep 12, 2013 | 02:18 PM
Staged07SS's Avatar
Administrator
Administrator
Not sure where zzp sources their axles.
That's about the size increase though.
Old Sep 12, 2013 | 02:21 PM
blueLNFftw's Avatar
I have heard several times before the ZZP ones are Napa, cant confirm though.
If you have another good one then toss it in.
Old Sep 12, 2013 | 02:30 PM
Staged07SS's Avatar
Administrator
Administrator
Just looked at zzp's site.
The S1 axles look exactly like the axles I installed.
Old Sep 12, 2013 | 02:38 PM
nice. thanks.
well our shop mechanic just took the car out to get lunch/try to diagnose, andhe doesn't think an axles would cause this side to side shaking. he's halfway convinced its my tires, for some reason. they are new tires, and the car wasn't doing this until the other day. my suspension is all tight and nothing should be out of alignment. ugghh...
Old Sep 12, 2013 | 02:43 PM
nice. thanks.
Maybe need rebalanced?
Sent from my Nokia 3100 using CobaltSS
Old Sep 12, 2013 | 03:51 PM
the wheels? idk. when i get home in half an hour i'm gonna jack her up and make sure everything's good and tight... if it all is, i guess i'll try and rotate the wheels front to back... and then i'll take my extra axle to a shop to get rebuilt.
Old Sep 12, 2013 | 04:20 PM
Whitnith's Avatar
This. It's surprising how much that can throw the car off.
Weights fall off randomly or if the wheel gets hot enough the glue will let go. I always can tell if I chucked a weight while on track.
Old Sep 12, 2013 | 04:25 PM
yellowsupercharged06's Avatar
i kinda have the same problem.... from 60-80 mph the steering wheel shakes side to side but the car dosent, its like a bad vibration i can feel it in the gas pedal too.
my alignment is off a tad but nothing crazy idk if this is the same as you or not
Old Sep 12, 2013 | 04:26 PM
Whitnith's Avatar
Wheel weights. Get them rebalanced.
Old Sep 12, 2013 | 04:38 PM
i did, even swapped the backs to the front ... same crap
Old Sep 12, 2013 | 05:31 PM
well, all my **** was tight. definate tear in my cv boot. ordered a new one from napa, gonna replace it tomorrow and see where im at
Old Sep 12, 2013 | 05:56 PM
iToastie's Avatar
Is it any time you're on the gas or just lower speeds?
Regardless, it's probably the axles from being pinched for a while after lowering it
Old Sep 12, 2013 | 06:00 PM
pretty much antime on the gas regaurdless of speed
the more im on the gas the more it shudders
Old Sep 16, 2013 | 03:44 PM
dcrep06's Avatar
i have this same issue, if i ever get on the gas my wheel will shake a little, alignment is fine last time i had them look at it, thought it may have been the spacers i had on, took those off. still shook. i have stage 2 axles and they are fine as well. last time i had the wheels balanced were when i got the tires last summer so idk if its that or not....let me know how it goes with the new axle.
Old Sep 16, 2013 | 04:00 PM
oh yeah! it was my axle. it got replaced, the shaking AND clicking noises i was hearing are gone!
i paid 50 for a new axle from napa, because i happened to know the guy from a party
it was free too! my dad had done a favor for the mechanic last week. i love living in a small town
Old Sep 16, 2013 | 04:33 PM
Cool story
Old Sep 16, 2013 | 06:23 PM
**** yeah! Good to hear man.
Old Sep 17, 2013 | 07:52 AM
dcrep06's Avatar
hmmm, well i have no clicking noises so its not the axles im at a loss right now for my wheel shaking problem maybe i should try and rotate the tires then. see if that helps any. kinda need to do that anyway. lol.
