slotted rotors
Old Nov 8, 2013 | 02:39 AM
Crav3's Avatar
slotted rotors
I was thinking of changing my brakes next paycheck. not really needed yet but wanted to be safe lol. anyway, I was thinking of getting drilled and slotted or just slotted since I have heard things about drilled rotora haha. any brands recommended?
Old Nov 8, 2013 | 07:05 AM
blueLNFftw's Avatar
Heard what "things"?
Old Nov 8, 2013 | 07:24 AM
thecutlip's Avatar
I went with powerslot, haven't had any problems so far.
Old Nov 8, 2013 | 10:11 AM
Omiotek's Avatar
you either do one or the other. not both unless its an oem rotor that was engineered for it. r1 concepts has some for a decent price or the powerslots are ok aswell. i prefer slotted rotors. cheap drilled ones crack.
Old Nov 8, 2013 | 11:25 AM
Shanedude's Avatar
Just go powerslot slotted they are tried tested and proven through the forums.
For the SS/TC I just put OEM back on I love the braking power it's got already.
Old Nov 8, 2013 | 12:12 PM
im runnin r1concepts slotted for about 2 years now. good rotors no warp yet. good braking no cracking or anything
Old Nov 8, 2013 | 02:34 PM
toolman's Avatar
I've been running R1Concepts drilled and slotted rotors for the last 113,000 miles. They're fantastic.
Old Nov 8, 2013 | 03:07 PM
Wired's Avatar
Also ran the slotted and drilled rotors from R1 on my last car for 30, 000 and my new car for about 5000 miles. Work great. Best rotor I have used.
Old Nov 8, 2013 | 09:31 PM
kzak104's Avatar
im just going blanks when i do mine, imo drilled rotors just look like **** after a while when the holes get rusted out.
Old Nov 9, 2013 | 12:51 AM
Crav3's Avatar
I heard of rust in the holes from drilled and that they crack. but on another note, which are better price? r1 concepts or powerslot?
Old Nov 9, 2013 | 01:23 AM
Wired's Avatar
Only my rear drilled rotors have rusty holes due to the fact that not enough brake dust is generated to cover/ cost them.
Never had cracks in any of mine but I only daily drive my car, not auto ross or track.
Old Nov 9, 2013 | 01:29 AM
Crav3's Avatar
I dont track mine either. daily driver but want a different look on the brakes and of course better braking lol
Old Nov 9, 2013 | 01:43 AM
duffman11's Avatar
R1 concepts is the way to go, 11K miles on mine and they are still holding strong. Drilled/slotted on the T/C
Old Nov 9, 2013 | 01:46 AM
andrewcarr1993's Avatar
If I were to ever get any rotors non OEM I'd get slotted and not drilled, they can crack when drilled and slotted actually has more gains than the drilled.
Old Nov 9, 2013 | 01:04 PM
I'm debating on getting R1's slotted or slotted and drilled when the time comes.
Old Nov 9, 2013 | 04:07 PM
Crav3's Avatar
I was looking at the prices and drilled and slotted are only $7 more than just slotted. and drilled only is like $20 more on r1 concept website. idk how much shipping is though
Old Dec 4, 2013 | 08:00 PM
josh6854's Avatar
Same here Ive heard drilled rotors "braking" under pressure.
Old Dec 4, 2013 | 08:05 PM
Sox-Fan's Avatar
Got Brakes?
drilled crack. slotted fill up with brake crud. get blanks, work better, less work, less cost.
Old Dec 4, 2013 | 08:14 PM
LS6Rally's Avatar
Im with this guy^
I had slotted, seemed to create a lot more brake dust, and they warped pretty quick. went with Centric Blanks and couldn't be happier!
Old Dec 8, 2013 | 12:01 AM
Nfamous60's Avatar
R1 PREMIUM slotted rotors man love mine great pricing as well.
Old Dec 8, 2013 | 12:07 AM
nobody2u's Avatar
I'm with this guy too. I think they look a little silly unless they are massive and on some high end car. Just my taste though.
Old Dec 8, 2013 | 02:33 AM
Crav3's Avatar
yea I think im just going with blanks lol
Old Dec 8, 2013 | 03:56 AM
Stamina's Avatar
I've been using R1 Concepts premium slotted rotors with HPS or stock compounds for 50,000 miles or so now with no issues. HPS proved good for reduced dust, but faded quickly. Stock put out a lot of dust, but are always like Chuck Norris' hands gripping your rotors whenever you need them.
Filling a rotor with holes reduces the mass that the heat is dissipated over, which can lead to premature fade, and they're already vented, so it's not really getting you much advantage while giving you the disadvantages of possible warping/cracking.
Slotted rotors are slotted to clean the surface of the pads to ensure good and clean rotor-pad contact. To those mentioning they found stuff in the slots - Good, because that's what they're there for! lol I bought them for this reason and because it helps wipe the water off the stock pads that are known to have issues when they get wet. The disadvantage to slotted is as mentioned above - pads wearing slightly faster and needing to wash the buildup out of the slots when you wash the car.
Old Dec 10, 2013 | 03:31 PM
m33pm33p's Avatar
Zero advantages on a cobalt running drilled or slotted rotors. Stock is fine, and safe if you run auto x/track days or brake like a mad man.
Jan 12, 2016 12:01 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
grampss
Sep 27, 2015 08:51 PM
dieGone
Sep 23, 2015 10:20 AM
