Some questions
Old Feb 17, 2011 | 07:04 AM
insylem's Avatar
Some questions
Ok I have some information that I have seen here and there that I would like to inquire about.
My cobalt, like many others, goes clunk over bumps at low speed.
But one thing I never hear talked about is, at low speed turning,
it also does it.
From what I've read, it sounds like the "clunk" low speed bumps is caused
by a worn out control arm bushing. Also I have heard that this can cause
wheel hop. I have an ingalls dampener and I used to not get wheel hop,
however now I do. I didnt really think much of the wheel hop since I hardly
ever get on it to where it would hop. I figured it was because I still have stock mounts. But when I read about the control arm bushings causeing hop I started to think back to when I first got it, I could peel out my wheels with no hopping.
I have had the Power Steering Recall completed, and there is no noticable differance
in anything. I never had any PS Problems before.
So would I have worn out Control Arm bushings? Or is something ealse going on? Or should I just turn up the music, because cobalts like to make noise.
Old Feb 21, 2011 | 05:07 PM
BULLETSSMOKE's Avatar
it also does it.
Does it pull to the left or right on acceleration? Because mine has all of that plus what you have.
Old Feb 21, 2011 | 09:04 PM
insylem's Avatar
It does alittle bit, but that's just torque steer, and from what I understand that's normal for a FWD to do that.
Old Feb 21, 2011 | 09:08 PM
royce777's Avatar
its the control arm bushings my went bad so did my dads
Old Feb 21, 2011 | 10:16 PM
scottherbert's Avatar
Also, loose sway bar end links can also cause a clunking noise.
Scott
Old Feb 22, 2011 | 08:32 PM
What about the intermediate steering column or whatever. I know my steering clicks when I turn the wheel.
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
