spherical control arm brushings, harsher than stock?
Old Oct 2, 2011 | 11:02 AM
Ronn2005's Avatar
For those of you with spherical control arm brushings how is the ride compared to ss/tc stock control arm brushings? Is the ride harsher or bumpier? Can you really feel better handling or less wheel hop?
Old Oct 2, 2011 | 11:22 AM
Wangspeed's Avatar
It depends on your roads. If you have pretty decent roads, the increase in MVH is minimal. As far as handling goes, that also depends. If you are just driving on the street, no, you will not really notice. If you autox or track, it's a mild improvement and helps prevent some camber loss, not to mention the stock bushing tends to tear.
Old Oct 2, 2011 | 12:07 PM
Ronn2005's Avatar
Thanks wangspeed. I want to put my money in the right places in my car.
At first I was going to get into autox, and then I realized it was expensive lol, so I am just looking for acceleration.
I put in rotated mounts, and that was a big improvement, and now I was thinking the spherical control arm brushings to further reduce wheel hop, but if its not noticeable, then I need to look for something else. Shocks, maybe? Better clutch and light flywheel?
BTW I am going with a 45 sidewall to help with launch.
Old Oct 2, 2011 | 08:48 PM
xxxxsh4d0wxxxx's Avatar
Rod end/Rod end bushings make noise. No matter what the application..
Over a gravel road, railroad tracks, or road with lots of imperfections they will make some noise, as Wangspeed said. It's nature of the beast.
I have them and love them. If you take a pry-bar and wedge it between the control arm and the sub-frame, right next to the stock bushing, and give a small pry you can just see how flimsy they are.. Not with spherical CAB's though. They are very stout and a great piece regardless if you auto-x/track.
Old Oct 4, 2011 | 09:59 PM
09sscalicobalt's Avatar
i have them and there great just make sure you torque them to 148lbs i found out the hard way lol
Old Oct 4, 2011 | 10:08 PM
What happened?
Old Oct 4, 2011 | 10:15 PM
been hearing clank clunk from front end on left side after getting them installed last month with the leading bushings and adjustable endlinks from powergrid ss lines and wilwood 570 john powell told me to check them and torque to 148 or 145lbs whatever and they turned about 1/4 to 1/2 around so yea they werent tight at all lol
Old Oct 5, 2011 | 09:22 PM
Powell Race Parts's Avatar
really drag racing is the cheapest to pay for a pass (although autox is pretty darn cheap as well) but the cost of drag race participation in terms of car stress/failure/maintenence, its the MOST expensive form of autoracing.
Old Oct 11, 2011 | 10:50 PM
Maven's Avatar
Ive got tens of thousands of miles on my PRS CABS. would never go back to stock.
Old Oct 11, 2011 | 11:04 PM
ItalianJoe1's Avatar
I was driving my old car the other day with my own custom solid CAB's, and they are still solid and quiet, makes the car feel totally different. They've been in there since '06 and have nearly 50K on them.
Old Oct 11, 2011 | 11:08 PM
Maven's Avatar
Yeah, more solid is def best way to describe it. Solid and direct. Mine actually have over 50k at this point. my balljoints are gonna wear out first
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
Coballin13
Sep 25, 2015 08:43 AM
