Springs on a 2.2 HELP!!
I wanna get some lowering springs for my 2.2 balt. i just dont know which ones to go with.
Can people with a 2.2 post pics and list what springs you have and the drop that it made. i dont want anything to big of a drop cause i will scrape all the time.
I have Progress Springs
http://picasaweb.google.com/gallaghe...altPicsLowered
these are zenn springs
2"front 2.5" rear
this will give yo a good idea of the wheel gap afterwards. those are 18" rims
2"front 2.5" rear
Last edited by 07cobaltowner; May 15, 2007 at 02:48 PM. Reason: Automerged Doublepost
I got Canuck Motorsport springs on mine. 1.9/1.6 drop. It leveled the car right out. Ride is excellent. Here are some pics:
I've had them on for about 6 months and havn't had any problems!
Stu
Stu
some places have sales. some are cheaper than the others. i just recently lookd into lowering my balt.
what else do i need to do to the suspension? struts? or just springs?
I looked into lowering my car a couple months back. i also bought rims/tires and wanted to know which rim size would look best with a certain drop. I ended up buying 17" rims w/ 215/45/17 tires. They looked the cleanest with Tenzo-R 2.0/2.5 drop. There are also SSC Springs that drop the LS 1.75 front / 2.25 rear. Which i think im actually going to go with because i have a 3inch exhaust, and if i drop my car 2.5 in the back, its going to be close and may crush it. Searching isnt that hard, it takes about 10 minutes and you will find everything you need to know on each of the springs out there. A drop of 1.75 - 2 front and 2.25 - 2.5 in the back will look great. And if you dont have a lip kit, scrapping should be too bad. you just have to learn to drive with it, thats all.
so the tenzo lower the same as eibach sport?
bump.
If you have jacked up roads u may want to go with the prokit from Eibach.. but if you arent worried go with the sportlines... The Tenzo's and H&R ones may be to low.. Definitely the H&R those are LOOOWWW
