Squeak When Moving From A Stop
I did some searching and haven't really gotten a solid answer so forgive me if this seems repetitive but...
Shortly after installing my Pedders I began to hear a little squeak just about every time clutch grabs ( KY 6 puck) and I start to move from a dead stop. I pretty much only hear it when starting from a stop. Never while driving, accelerating, turning or anything like that. it sounds like its coming from the front underneath the car and it never did it until I put the Pedders on which was 3 mos after clutch so it aint the clutch. The sound is most reminiscent of metal on metal squeaking.
After searching I saw someone say it could be the end links? Another person suggested that my steering rack may need the spacers?
Has anyone experienced this? How'd you fix it? It's driving me nuts.
I HAVE THIS NOW.
Mine comes from the passenger side, sounds like the wheel well area.
It only started recently and I've been on coil overs for awhile now.
I posted about it in my region thread, and got back that it could be the breaks or end links.
Does your squeak frequency increase when you start picking up speed from a stop where it eventually stops?
I get a squeek too but to me it sounds like its coming from the clutch or something. I will be putting on rack spacers here soon. It started happening after i installed my KY Stage 3 - 6puck as well (and stage 2 rotated mounts)
I HAVE THIS NOW.
Please keep me posted if that takes care of it. I'm at wit's end.
what did you do with your flywheel?new, resurfaced, reused or what? endlinks arent hard to diagnose pop the wheels off and take a look..... replaced the throw out bearing? is your clutch bled completely? just some things to go over.
