SS brake lines
Old Mar 1, 2010 | 12:14 AM
Do_WorkSS's Avatar
SS brake lines
whats the benefits?
Old Mar 1, 2010 | 01:50 AM
bri2203's Avatar
of stainless steel brake lines?
Old Mar 1, 2010 | 02:18 AM
Do_WorkSS's Avatar
yes. im looking at the goodridge brake lines for $115
Old Mar 1, 2010 | 11:51 AM
Wangspeed's Avatar
They're actually teflon plus a stainless steel braiding and usually another cover over that. Like any aftermarket part, there are pros and cons.
Pros
  • Generally improved pedal feel
  • If routed properly and not twisted, should be more durable if coated
Cons
  • Misrouting a line could mean that it rubs and ruptures
  • Grit can work its way underneath the braiding, which would then cause a rupture. This is not as much of a concern when there is an additional coating over the stainless braiding
I've had failures of both. Once because a stainless line was misrouted by someone helping me out during a race. The line slowly abraded against the wheel. Fortunately, it was a somewhat gradual failure. Another time, one of my stock Evo 8 front brake lines completely pulled out of the hose end, leaving a rubber hose spewing fluid at 100+ mph on track. That was the end of that car.
For me, I've got to have stainless lines with a clear coating, and proper mounting points before I go on track. Street car? Don't bother changing them unless the stockers are old and cracking.
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
Sep 27, 2015 08:53 PM
