SS/SC big brake kit.
This looks nice.
http://www.gravanatuning.com/applica...ront_Brake_Kit
http://www.gravanatuning.com/applica...Rear_Brake_Kit
895 for the front
1195 for the rear
895 for the front
1195 for the rear
Hey two questions one: Why are they only 2 piston in the front and 1 in the back, why wouldn't they make it 4 in the front and 2 in the back. And two do they work with the abs computer on the car b/c if they don't your braking will be worse.
They do work with the ABS sensors, and as far as not using a 4 piston front and a 2 piston rear, I think it has to do with the size of the master cylinder. It can't make enough pressure to actually function with a bigger caliper size than those. I will ask tomorrow when I go to work and actually find out why. Also these calipers compared to the stock ones they are alot lighter. It's all about the unsprung weight.
I understand about the unsprung weight but the prce for such a benifit is way too high. I think they are reaching for the stars on the one. I would have to thing realy hard for 1000 for all 4 but 1000 for 2 that is out of the question. besides that I realy want them.
That's why if I could get a bunch of people togeather to order them all at once I might be able to get them discounted. I understand that almost $2000 for a 4 wheels is not chump change, but if you wanna play you gotta' pay
I keep gnagging for my brake kit, so more than likely I'll be the guinea pig for the people on the forums except for the one guy. His car was used to develpe the kit.
Originally Posted by n4ggs
big breakes are cool and all but you have to watch out for the significant powerloss at the wheels. 5% is not uncommon loss from the added weight the big breaks add.
"GOT BRAKES? We didn't think so! SSBC now offers the ultimate solution to the braking problems on GM's new Delta platform! Big stopping power in a little package."
Since when is their braking problems on the SS? Don't we have have the best brakes in our class? Don't get me wrong I love nice brake kits but I don't think this is too neccesary until you do some serious performance mods.
here's a great question. Have you ever taken your cobalt ss over 130? Well i may or may not have and let me tell you, stepping on the brakes at that speed is scary. If anyone has ever had a big brake kit on their car they know what i mean. The brake fade from 130 is absolutely insane and the bigger brakes don't fade as quickly. Convert to a big brake kit and tell me if you'd EVER go back to stock brakes ever again, there is no such thing as having too much brake power.
Uh stepping on the brakes in any car is going to be scary at that speed, aside from extreme performance cars. And the only reason why they're better at those speeds is because they're a hell of a lot lighter then the SS... and more aerodynamic too.
Originally Posted by BeastlyTA
I dont understand your reasoning behind that. The calipers dont move so weight isnt a concern there and the rotors used would not weigh much if any more that the solid stock ones.
when you add both mass and diameter the effects get exponetional. the same thing happens with bigger wheels and tires. all else being equal, a wheel tire combo that places more of its mass at the outside will dyno less at the wheels.
how much bigger are these rotors than the stock ones? i know the stock ones are pretty big and for these it says 17" wheels are required for clearance. dont the ss/sc brakes require at least that?
