SS/TC E-Brake Failure
Old Dec 14, 2011 | 04:33 PM
mysweetSS's Avatar
Unhappy SS/TC E-Brake Failure
Has anyone had problems with their SS/TC e-brake? I had the dealership tighten them because they weren't holding at 35,000 miles. And now at 39,000 miles they aren't holding again!!!! Does anyone know of a recall or a solution to this problem? Or do I just need to change the Brakes? I haven't even had to change the front brakes yet.
Old Dec 14, 2011 | 04:55 PM
rraines21's Avatar
i just recently had the same problem fixed. the dealership put on new rear calipers and that solved it. i had mine go out numerous times and my drive is on a hill. since they replaced the calipers though i havent found my car at the bottom of the hill again.
Old Dec 14, 2011 | 04:56 PM
AndrewSS/TC's Avatar
i have this problem, but just dont care.
Old Dec 14, 2011 | 04:57 PM
RHZ's Avatar
RHZ
My rear pads were down to the metal at 44K miles. If you've never lubed the caliper slides on your rear brakes your rear pads definitely worn unevenly. The slides dry up fairly quick on the caliper and need to be lubed to prevent uneven pad wear for max pad life. I'm guessing your rear pads are in need of replacing... Your front pads should last must longer. My front pads have 50k on them and still have plenty of beef.
BPacak's Avatar
Vtec Rep
seems like it always happens with the cold weather. make sure you pull it up all the way and ALWAYS put your car in gear when you have it parked. and yes there is a way to tighten it but ive never done it.
Old Dec 14, 2011 | 04:59 PM
theamericanautos's Avatar
yea, I had the same issue and they did the same fix. They tightened it once and I came back and they replaced it (under warranty).
Old Dec 14, 2011 | 05:07 PM
nobody2u's Avatar
When I first bought mine, the Ebrake went, the dealer took care of it though.
Old Dec 14, 2011 | 06:03 PM
iboost's Avatar
Pull the rear two sections of the center console and make sure the cables are good. I had this issue once and one of the cables was undone
Old Dec 14, 2011 | 06:21 PM
JacBlackSS/TC's Avatar
i took mine to the dealer they wouldn't fix it b/c the spring was missing but i can't figure out where to buy the spring at to replace it myself
Old Dec 14, 2011 | 06:25 PM
iboost's Avatar
dealer wouldn't fix mine because I put R1 Concept Pads and Rotors on it...lol
klloyd's Avatar
My e-brake sucks too, I always feel like it isn't holding good enough but I still only use that and never leave it in gear. Waiting to come out from work one day to see my heat exchanger smashed because it rolled into the curb.
Old Dec 14, 2011 | 06:29 PM
turbohornet88's Avatar
mine is starting to get soft. my brakes are worn. mite be the problem......damn....
Old Dec 14, 2011 | 08:14 PM
gotboost?17's Avatar
Nothin Stock
if had this problem too, replaced the rear caliper and its back doin it again, but i did notice today it felt tighter then before i donno, ill tell them to fix it again lol
Old Dec 22, 2011 | 11:43 AM
Shanedude's Avatar
12-14-2011 06:25 PM
klloyd My e-brake sucks too, I always feel like it isn't holding good enough but I still only use that and never leave it in gear. Waiting to come out from work one day to see my heat exchanger smashed because it rolled into the curb.
Lol what? Why don't you just put it in gear then? You're just waiting for a facepalm.
My 2010 SS/TC 55k on it and my e-brake is near it's last click.
I went to the dealer and the service manager told me drive in reverse and brake and few times and some grommet will self tighten. Regardless I am a huge believer in reverse parking, and have been doing it since day 1. Tis not working...
Old Dec 23, 2011 | 06:11 AM
Nothin Stock
on mine only one wheel will lock up, other one spins free. u know u drive a cobalt when lol
Old Dec 24, 2011 | 05:03 PM
guitarenvy's Avatar
seized cable.
Turbo Johnny
Feb 21, 2019 09:41 AM
Jan 12, 2016 12:01 AM
Sep 27, 2015 08:53 PM
metroplex
Sep 27, 2015 07:48 AM
