SS/TC Sedan spring height
Is it the same as the coupe? Curious because I'd like to get the Pedder springs and hardcore OTTP bar if they are. Not looking to drop the car (I do need to carry friends in the back, hence the sedan), just improve handling for my new track toy.
Thanks,
Warren
Thanks,
Warren
Thanks for the confirmation of the plan. Since it's the end of the season, I probably won't grab the bar til the weather clears up. No need for a fat rear bar in winter.
Warren
Warren
Understood. I made the assumption that they were the same since there's only one version of the Pedder springs. Well, so let me ask this about them then. How about compared to the coupe version?
I have two concerns with just a spring swap. Loss of travel, and unknown spring rates. I want a reasonably stiff rear spring setup to help keep the inside front planted since we power the wrong wheels ;-)
Warren
Warren
i fill my car up with peeps all the time.. got eibach sportlines on mine... no rubbing... and the drop seems to be the same as the pedders... however my springs have sat a little better now so its slightly lower... i gotta get pictures so i can show you...
but i run 235's and im not rubbing
Warren
Warren
The Pedders springs do not coilbind so already better than eibachs and the rest of them.
The rake helps turn in. An OTT rear bar will help turnin even more, that bar is the ONLY chromalloy bar you can buy. The rest of aftermarket rear bars except Eibach are of different materials, the last test I did on one showed the material to be mild steel. Eibachs are good spring steel, however, just not chromalloy
What you need to know is your car will be very good and will handle well on Pedders. The loads of a 4 door with people in it will not challenge the Pedders. Any of the other drop springs I have seen or used - Eibach, H&R, coil bind, rust and sometimes (H&R) break. No worries like that with Pedders.
What happens if you put on an OTT rearbar is that you not only change the twb stiffness you change the roll center. That is important for you.
So go buy 'em you wont regret it....
I've a slight disagreement about the roll center changing. That would require a geometry change, something a bar alone couldn't accomplish. Still think the hardcore bar is the one for me though.
Warren
Warren
hmm. Not an unusual comment, but as the GM chassis engineer pointed out to me, most folks are not comprehending the twisting beam and how it works.
Rear roll center location is basically determined by axle pivot location in relation the axle shear center location. Since the antiroll bar changes the rigidity of the rear axle its going to affect the shear center, you also get additional deformation of the suspension bushings, further moving the roll center(since the axle pivot location has moved) This is at least how I understand it to function
