stance coilover customers
i received my stance coilovers and i installed the back ones the first night and they fit perfectly. i went to install the front ones the next day starting with the drivers side and noticed to three bolts and the top did not line up with the holes, then i noticed both of the top mounts were for the passenger side. i then started looking a pictures of others installs on here and noticed the springs on mine look completely different. i contacted them about both problem and sent them a picture and they said they are the right ones and they will send me the right parts for the drivers side. but there is no way they can be the right springs.
here is a picture of the ones i received:
and heres a picture of them on the THMotorsports thread:
and heres a picture of another members before install:
and a picture of the two passenger side mounts:
am i correct that they are the wrong springs?
i got them from THMotorsports but its not there fault at all, to me it seems like stance put them together wrong before they shipped them to THM. Adam was helpful and told me to contact stance directly and they will fix it. plus gave me a good price. however stance is telling me they are the right ones so ill have to send them a bunch of pictures showing them they arent right since they cant look themselves. i havent been able to reach them by phone either so i have to wait two or three days to get an email response usually
heres another picture showing that they arent right.
i just did, and i already sent them a picture of the spring and they said they were right but the springs a way too long, i would maybe be able to lower my car an inch (if that) before i couldn't adjust them anymore because it would hit the bottom of the spring. and yeah both of the top plates are the same, both for the passenger side and you cant flip them upside down or anything.
the top plate is not machined correctly send it back HSD make them for Stance this has happened before. You also have a straight spring it wont allow you to go lower than 25.5 inches ground to fender lip through the axle center line. So send them back get the right stuff - correct top plates and the football shaped front spring. Good luck.
