Stance coilovers installed
^^^^^ do you have a pic of your car at the highest point???????????????
i want to compare that to stock. i have mine (stance coilovers) in the garage for 3 weeks, but can't install them cause if my wife knows, the chocolate factory could be close for more than a month. and that's a BIG NO-NO.
and which is easier, front or back?? since i guess i'll be doing 1 side first then the other on another day.
yes togue factory is kind of pricey. theres a few shops that do corner balancing just have to remember. my buddy withhis track mustang goes somewhere. andrews race shop sells a lot of road racing stuff so they are a good source of info.
im not sure how others installed it but when i first dropped the rear all the way my fenders would be even with the top of my rim so rear tires would be fully tucking, and a good amount of space for the bump stops.
as for the front i can go as low as almost the top of rim matching the fender, i didnt wanna drop it reallly really hard until they settled, but this is pretty low already, also i got 6kfront springs and 6k rear springs, not the 5k rear that comes factory. then front dampening i have it how they came factory and rear i have it set to 12 clicks towards hard
I'm not sure how your doing this lol. Are you using stance coilovers? I'm almost sitting on the bumpstops in the rear and the perch is screwed down all the way (ie lowest setting). I've only got about 1/4-1/2'' left to move lower on the front.
I don't really see what it could hurt. I don't think there is too much of an angle to affect the axles. I couldn't tell you about handling, honestly. I haven't been in any auto x events or road races. I would like to this summer though.
for the front i didnt touch the top perch which stance says dont adjust because its only for spring load, so i just moved the bottom mount up/down depending on how low you want it, than lock the bottom perch to the bottom mount.
for the rear i installed it with the springs and the ride hieght i wanted it at then matached the shocks to it.
kinda hard to discribe it lol
Here's the problem though. I thought I had more room to go lower in the front but I clearly don't lol. The back is the same way. Maybe there is something different between the sc and tc that I'm not thinking about.
By the way, did anyone get dustboots for there coilovers?
i got dust boots on the rear only..... the only real difference i think that would effect how low the lnf sits vs the lsj is the lnf's have a different knuckle up front. i dont know if that would change how the cars sit from the factory which would later alter how they sit on coilovers.
