Stance people! Help!
Old Jul 3, 2012 | 10:38 AM
chevychad05's Avatar
I'm pretty positive I'm going to to thru with bagging my car.. I found an Air Lift digital management kit on AutoAnything.com for $2,595.
I'm clueless when it comes to wheel sizes, offsets, etc.. I found a set of Vette sawblades with adapters, specs below:
Front (without adapters): 17x8.5 +56
Rear (without adapters): 17x9.5 +54
Front (with adapter): 17x8.5 +25
Rear (with adapter): 17x9.5 +22
Tire sizes are 205/40 & 215/40
The adapters are 1.25" thick
My stock specs are 15x6 +42 (4-lug)
195/60 tire..
Would these fit? And if not what would?
I'm a noob when it comes to suspension haha
Can rear camber be adjusted? And would the rears rub the air bag?
This is on a 05 LS sedan btw ..
Any help would be great!
http://www.flickr.com/photos/chadkreiling/7440130698/http://www.flickr.com/photos/chadkreiling/7440130698/ by http://www.flickr.com/people/chadkreiling/, on Flickr
Old Jul 3, 2012 | 10:43 AM
BLAZIN07SS's Avatar
I'm too JDM for you
the adapters are for a 5 lug car. your adapters would have to be huge to go from 4 lug to 5 lug
Old Jul 3, 2012 | 10:44 AM
Wangspeed's Avatar
I needed a good laugh this morning.
Old Jul 3, 2012 | 10:45 AM
so you dont think it will fit?
I looked at rotiform NUE's too..
17x8 all around.. et either 20 or 30
Old Jul 3, 2012 | 10:56 AM
C_A_D88's Avatar
^ your car will not be that low even on bags...
Old Jul 3, 2012 | 10:58 AM
BLAZIN07SS's Avatar
I'm too JDM for you
from airlifts site
Old Jul 3, 2012 | 11:14 AM
Gtfo I'm asking for help so stay off my thread if you are going to be a dick.
Old Jul 3, 2012 | 11:18 AM
breds2k's Avatar
yea! thatll teach him.
Old Jul 3, 2012 | 07:07 PM
BLKLS's Avatar
Hahahaha! Really tho you should listen to Wang, he knows his ****.
Ok if you wanna have adjustable rear camber you need to get the set up from Powell, it is a conversion kit to switch to rear disk. Don't know the details but thats about it.
Old Jul 3, 2012 | 07:32 PM
c1_c1rca's Avatar
Old Jul 3, 2012 | 08:40 PM
C_A_D88's Avatar
If u have drum brakes u can do camber in the rear , powells set up is if u have rear calipers already n wanna put camber in the rear, his setup allows the caliper to move with the rotor when adding camber, u don't run into that issue with drum brakes
Old Jul 4, 2012 | 12:51 AM
tru2nrtt777's Avatar
You can just use camber alignment shims on the back the whole hub assembly is held on with 4 bolts.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
OrangeCoba
Oct 1, 2015 10:00 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
soaxin
Sep 26, 2015 08:41 PM
soaxin
Sep 26, 2015 08:39 PM
