Steering wheel wobble (lets solve this damn problem)
Old Jun 6, 2010 | 12:24 PM
rallyracer's Avatar
Arrow Steering wheel wobble (lets solve this damn problem)
Sounds like many of us are having this same problem...At speeds (over 30mph) my steering wheels wobbles. Car doesn't feel stable in the twisties anymore either
Some have blow money at the dealer which end up not fixing the problem.
Who has had this similar issue and what was the cause?
Things Ive thought could be the cause:
* wheel bearing
* outter tie rod
* CV joint
* ball joint
* control arm bushings <---pretty sure these are not the cause.
* Intermediate shaft bearing
* axles
* alignment <--- car doesn't pull right or left much at all, so this could be some but not all of the problem.
These have been ruled out: \/ ...On my winter rims and tires I still have the same problems.
* Tire balance
* Bad tire
* bent rim
Old Jun 6, 2010 | 12:32 PM
yamaha288's Avatar
I have the same problem and I know I have a bad cv joint (clicking and slack) taking it to the dealer this week. I will post results
Old Jun 6, 2010 | 12:38 PM
ssweeet's Avatar
I've been dying to find a solution to this. I've been living with this problem at least for three months now.
Old Jun 6, 2010 | 12:40 PM
OneCOLDBIZL272's Avatar
Bad brake caliper, warped rotor? I had the problem it was a seizing brake piston in the caliper when it got hot, and caused it to drag and the wheel would shake it could be a number of things
Old Jun 6, 2010 | 01:05 PM
damien's Avatar
Yup, having this too. Mostly when I accelerate at a quicker than normal pace.
Old Jun 6, 2010 | 04:28 PM
qwikredline's Avatar
what wheels do you have?
Old Jun 6, 2010 | 04:35 PM
BlackBaltSw's Avatar
What lowering springs are you running. As soon as i installed my H&rs i had this problem, its from like 25-40 then goes away, til WOT. Im thinking its the car being too low and the axles binding or something similar.
bump, lets fix this ****!
Last edited by BlackBaltSw; Jun 6, 2010 at 04:35 PM. Reason: Automerged Doublepost
Old Jun 6, 2010 | 04:45 PM
trevor151's Avatar
torque steer? lol jk
Old Jun 6, 2010 | 04:58 PM
rallyracer's Avatar
Im on Pedders TC set up with the rack spacers...although I was on Sportlines for the past 3 years. Maybe my axles are shot. When I look at them nothing appears out of the norm.
I have SS/SC wheels.
The steering wheels is wobbling all the time while cruising at hwy speeds too (55-80) ...the car just doesn't feel stable anymore
Old Jun 6, 2010 | 05:20 PM
csementuh's Avatar
I have a bit of wobble at highway speeds also. Happened after I hit a pothole. Replaced tire. Tire place balanced both front wheels and said that neither was bent, so now I'm stuck. Had an alignment also. I have rebuilt the front suspension with new parts except for the rack and axles. Hmm...
Old Jun 6, 2010 | 05:32 PM
outtamymind's Avatar
have any of you considered the roads you drive on. i know on particular roads up here i will get a steering wheel shake and other roads i won't.
Old Jun 6, 2010 | 05:45 PM
rallyracer's Avatar
Well if the car did this since day one I could see that being the case but it hasn't.
Old Jun 6, 2010 | 05:48 PM
makes sense, was just throwing that out there. has anyone replaced the stabilizer end links and still have this happen.
Old Jun 6, 2010 | 05:51 PM
csementuh's Avatar
My end links are very new. They're the beefier than stock Moog replacements.
Old Jun 6, 2010 | 06:00 PM
damien's Avatar
So i played with the axles a little and I have some in and out play and up and down. My tie rods and end links appear to be fine. What boggles me is it's inconsistant. Sometimes it's much worse than others.
Old Jun 6, 2010 | 06:03 PM
rallyracer's Avatar
I think the axles are suppose to have a little play, mine do the same thing.
My tie rods and endlinks are also in good shape.
How would we know if are ball joints are bad? I have my control arms off the car right now. The ball joint move around a bit if I try to move it around by hand.
Old Jun 6, 2010 | 06:07 PM
see the classic symptom of wobbling steering wheel is improperly balanced tires or improperly mounted tires (road force matching is available on certain balancers) a bad roadforce will cause a wobble as well
Old Jun 6, 2010 | 06:14 PM
rallyracer's Avatar
Yeah idk...many have done with this guy did \/ and still have the problem.
Old Jun 6, 2010 | 06:24 PM
csementuh's Avatar
^^ Yessir, I've covered most all of the bases lol. It has been an excuse to upgrade some stuff, but I still have the problem sometime. Now it's even worse with the TVS torque steer lol.
The only other thing I can think of is wheel bearings, and the steering rack actually being worn. The dealer said they'd take a look at it, but it seems like a PITA, and my dealer is slow. I had to take it back 6 times to get them to replace all of the worn trim in the interior lol.
Old Jun 6, 2010 | 06:29 PM
rallyracer's Avatar
Im still looking at my intermediate shaft bearing as well...
Old Jun 6, 2010 | 06:34 PM
balancing and roadforcing are 2 differen't things. balancing only makes the wheel balanced as the name states. road forcing is literally matching the tire to the rim with the high and low spots of each. most of the time a tire mounting will go fine without the need for road forcing but other times they will not. GM's spec for our cars is no more then 18lbs of road force. most shops will not roadforce unless requested to roadforce because it takes longer. sometimes you even have to swap tires to a differen't rim to get them to line up properly
Old Jun 6, 2010 | 06:41 PM
rallyracer's Avatar
Aaaaa, I see /\ ...we'll my tires were great on my car for the first years.
When I get new tires I'll let the know, but I still pretty sure there's an issue somewhere else.
Old Jun 6, 2010 | 08:55 PM
the cv joint shaft shaft should move in and out a little.should NOT Moveup and down...gmsc.net lol
Old Jun 6, 2010 | 09:56 PM
damien's Avatar
I keep forgetting to join that site. Coming on over!
Old Jun 6, 2010 | 11:14 PM
ya its just something that could potentially cause a wobble as well.
