Steering wheel wobble (lets solve this damn problem)
Old Jun 9, 2010 | 03:10 PM
picsbypenny's Avatar
i think its the CV joint mine does it but thta cuz when i drag race i leave around 3k and im slammed so the geometry of my suspension is off
Old Jun 9, 2010 | 03:18 PM
rallyracer's Avatar
I've been driving around now on my ottp CABs and the wobble seams to have gone way down...not sure if this will last but for now its alot better!
So maybe all along it was the damn CABS ...I'll keep you guys updated.
Old Jun 9, 2010 | 04:05 PM
Jskip27's Avatar
I'm sick of the wobble. Cruising at 55-65 is absolutely horrible. My buddy with a 2002 ep3 hatch said he had the same problem when he lowered his (Which has McPherson style front struts) and he said he needed inverted tie rod end links to solve the problem. By inverting the endlinks stress is relieved and the wobble is reduced
Old Jun 9, 2010 | 06:26 PM
damien's Avatar
Today I was cruising steady 95+. Very slight wobble. My wobble ONLY occurs when I give it more 'oomph' and get the rpms going. Not really a wobble either, more like major shimmy. I literally have to fight it 100% if I go WOT.
Old Jun 9, 2010 | 11:19 PM
BlackBaltSw's Avatar
Mine only wobbles under acceleration. usually from 20-40. Wtf causes this...
Old Jun 10, 2010 | 12:15 AM
outtamymind's Avatar
splitting tires can cause a wobble as well. most tire guys that change your tires don't know what this is or how to detect it.
Old Jun 10, 2010 | 12:27 AM
Whining-devil's Avatar
yea i get wobble too
Old Jun 10, 2010 | 12:34 AM
elecblue06's Avatar
i have this issue.. and i had my axles replaced.. still persists endlinks are new, struts are new, tires are balanced.. I've been told it might be control arms or the bushings allowing too much movement..
it only happems to me at speeds under 40 though
Old Jun 10, 2010 | 01:07 AM
ChevyRockstar's Avatar
I have this on a 100% stock 06 SS, there was a bulletin for GM to replace the intermediate shaft. I haven't had this changed/replaced i hope it goes aways, but according to the bulletin it will only stop the clunk you hear when turning from a stop
Old Jun 10, 2010 | 03:33 AM
rallyracer's Avatar
Guys, Id look into the ottp CABs ....seams to have helped greatly
Old Oct 10, 2012 | 08:20 PM
  #36
seeyaass's Avatar
Okay I have a similar wobble.. Don't feel it much in the steering wheel.. Started off very very light and over a 5-6 month period now it's terrible.. Depends on load, sometimes it will wobble extremely bad that I have to let off the gas.. Sometimes it won't wobble much.. Sometimes I cando a wot pull and not feel it too bad.. Other times it feels like my wheels are square! You can feel it in the steering wheel but not bad. More so in the feet, seems like passenger side but I could be wrong. Doesn't do it under braking..that I know of. Help startin to think its the trans/clutch.
Old Oct 11, 2012 | 06:50 AM
  #37
Wangspeed's Avatar
If you were closer, I could take a look at the car. Up to you, but I'm willing to take a look if you come down to Manassas, VA.
Old Oct 11, 2012 | 10:24 AM
  #38
danpatmor's Avatar
I had a warped rotor, replaced it and the wobble went away. I still have a little slight wobble when accelerating hard, but im slammed on coils, need motor mounts.
Old Oct 11, 2012 | 11:15 AM
  #39
seeyaass's Avatar
I har new zzp rotors and pads as of a month ago..
Old Oct 11, 2012 | 12:32 PM
  #40
SaberD's Avatar
jack up the car so the tires are off the ground.
put your hands at 12 oclock and 6 oclock and push with one hand and pull with the other in both directions. if there is any play, this could be indicative of bad ball joints or wheel bearings.
put your hands at 9 oclock and 3 oclock and push with one hand and pull with the other in both directions. if there is any play, this could be indicative of bad tie rod ends.
with the car lowered, turn the wheel all the way to the right. kick the front of the passenger tire and see if there is significant movement. if there is, this is indicative of a bad lower rear control arm bushing. do the same with the opposite side.
in an open parking lot, cut the wheel all the way to one direction, put the car in reverse, and drive around in a circle with the wheel at full lock. if you hear a repeated clicking noise, then you have a bad cv joint. repeat with the wheel at opposite lock.
report back with your results.
Old Oct 11, 2012 | 12:36 PM
  #41
SaberD's Avatar
Originally Posted by rallyracer
How would we know if are ball joints are bad? I have my control arms off the car right now. The ball joint move around a bit if I try to move it around by hand.
there should be no play in the ball joints. replace them if they do.
Old Oct 11, 2012 | 01:31 PM
  #42
seeyaass's Avatar
I know how to check for wheel bearings and tie rods lol.. Did it 100 times no play at all.. Control arm bushings are good.. Changed the passenger side the other day, axles are good I wish it was something that easy.
Old Oct 11, 2012 | 06:51 PM
  #43
seeyaass's Avatar
Got. 4 new tires mounted and balanced. Still wobbling like a ************.
Old Oct 12, 2012 | 11:06 AM
  #44
SaberD's Avatar
replace that loose ball joint you were talking about. have you inspected the strut tower bushing and bearing?
Old Oct 12, 2012 | 11:11 AM
  #45
seeyaass's Avatar
Loose ball joint wasn't me lol.. And no I haven't I'll check that now lol
Old Oct 12, 2012 | 11:34 AM
  #46
SaberD's Avatar
oops haha sorry about that. have you checked the axles for runout? thats about the only thing left i can think of.
Old Oct 12, 2012 | 01:39 PM
  #47
seeyaass's Avatar
What's runout? I wiggle them both back forth up/down.. Small amount of play side to side nothing abnormal or bad..
Old Oct 12, 2012 | 02:30 PM
  #48
Wangspeed's Avatar
You haven't done anything stupid like bottom out the coilovers, did you?
Old Oct 12, 2012 | 03:29 PM
  #49
SaberD's Avatar
runout means out of circularity. if they are bent beyond spec, it will cause the wheel to wobble. you will need to take it to a shop, and they will have the proper measuring equipment. However, if it's real bad you may even be able to tell visually. You might be able to do it at home if you have a dial indicator and something to hold it in place while you turn the wheel and check various locations along the axle. i'm not sure how much would be out of spec though.
also, a small amount of play isnt anything to worry about.
Old Oct 12, 2012 | 04:00 PM
  #50
seeyaass's Avatar
Took it to a reputable shop.. Drove it and said it was driveline related but not axles..
