Still A Clunk
Old Nov 10, 2014 | 03:32 PM
talkeddelta8's Avatar
Still A Clunk
So this weekend I Replaced a ton of front end parts including, front struts and strut mounts,
sway bar links and CABS. I still have a clunk in the front end when hitting bumps. It it a lot better then before but still pretty obvious. I did also install SSC lowering springs.
I aligned vehicle as well.
Any ideas on what it could be??
Thank you
Old Nov 10, 2014 | 03:35 PM
umrdyldo's Avatar
Thank you
If you did the sway bar end links and the CABS that's a good start.
Did you replace the sway bar bushings? What about the front CAB's?
My guess is sway bar bushing.
Old Nov 10, 2014 | 04:22 PM
LNFTX's Avatar
Sway bar bushings
Steering intermediate shaft
Ball joints
Tie rods
Old Nov 10, 2014 | 04:26 PM
Originally Posted by LNFTX
Sway bar bushings
Ball joints
Tie rods
the tie rods and the ball joints are tight. so it either has to be the sway bar bushings, and it doesn't clunk when turning for the intermediate shaft.
Old Nov 10, 2014 | 04:50 PM
LNFTX's Avatar
Steering shaft will do it on bumps too especially if it is on one side and causes the wheel to move side to side
Old Nov 11, 2014 | 02:22 AM
kzak104's Avatar
disconnect swaybar endlinks and drive it, if the clunk goes away its probably the bushings
Old Nov 13, 2014 | 08:01 PM
Jesse's Avatar
Once you tighten the sway bar links, then drive it, then you have to retighten them. 90% of people I've helped with clunking and new sway bar links this was the problem.
Old Nov 13, 2014 | 09:35 PM
kzak104's Avatar
if thats the case then they didnt tighten them properly in the first place. never have i had to do that on any car.
Old Nov 14, 2014 | 12:37 AM
Jesse's Avatar
Yep, that was the case with 90% of the people I've helped with clunking. Tighten them and feel like you did good, then drive it and realize you didn't
marquis
Aug 29, 2019 06:07 PM
Sean Cummings
Sep 11, 2015 09:35 PM
hispano1
Apr 27, 2007 10:35 AM
Blown 4-banger
Nov 8, 2006 10:58 PM
edash
Feb 23, 2006 01:12 PM
