strut bearings
Old Jan 2, 2011 | 10:23 AM
DEZZIE41's Avatar
strut bearings
is there a way to change them withouth having to get an alugnment again
Old Jan 2, 2011 | 10:47 AM
C_A_D88's Avatar
yea take um out...put new ones in
Old Jan 2, 2011 | 10:48 AM
DEZZIE41's Avatar
i know that im not a complete ******* i asked can they be replced with having to get an alignemnt caus eu have to pull the strut off the car
Old Jan 2, 2011 | 10:55 AM
scottherbert's Avatar
Since camber is fixed with the Cobalt struts and you're not changing tie rod ends (which could change the toe), there should be no alignment changes (significant anyway) from what you want ot do.
Scott
Old Jan 2, 2011 | 01:03 PM
Wangspeed's Avatar
Probably not enough to get an alignment for, unless it's been a while anyways. Like Scott said, unless you've ovaled out your bolt holes (or using camber bolts), it should be fixed. If you want to make sure it stays, scribe a mark across the strut and knuckle in 2 places, and make sure they line up when you're putting it back together.
Old Jan 2, 2011 | 02:08 PM
Even with ovaled-out bolt holes (which I used to use), if you scribe a mark (as described above), you'll still be OK. Go for it!!!
Scott
bigdeertz
Nov 17, 2016 09:41 AM
HEATON
Oct 16, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
