Strut bolt
Old Jul 21, 2008 | 10:17 AM
Dunkinuts's Avatar
Thumbs down Strut bolt
Well as you can prob. tell, its not going to be good. Well I have had a mild noise (only really over sharp bumps in my front pass. side for a little why) So me and my friend went back to the garage to see if we can find out what is making the sound. long story short. We/stress/whatever broke the strut mount bolt (one of three). Now my question is what part number is that? how much? I limped the car home and it has been sitting b/c Autozone didn't have the part. The dealership service department is only open 9-5 monday through sat.
Any help would be great!!
Old Jul 21, 2008 | 11:05 AM
qwikredline's Avatar
any bolt will do similar size and lengthor buy a new part...
Old Jul 21, 2008 | 11:10 AM
eazyasone23's Avatar
hmm i get a slight noise when im driving over speed bumps, but im too lazy to check right now. i think mine is because i didnt put it tight enough so their is slack. good luck with that problemo
Old Jul 21, 2008 | 11:15 AM
mrniceguy8211's Avatar
Make sure it is a grade 8 bolt. Let me know if you need one, I have 2 extras from when I put the camber adjusting bolts in my car.
Old Jul 21, 2008 | 05:27 PM
Dunkinuts's Avatar
yeah i am getting ready to head over to the dealership i will let you all know.
ok update, figures they don't carry any hardware in stock they order everything. LAME!!!! so I they also needed a vin number which i didn't have so i will have to head back tomorrow and hope it comes in before i leave for vacation.
Old Jul 21, 2008 | 05:30 PM
D4u2s0t's Avatar
do you mean the one that's in the engine bay? the top strut mount? if so, you have to buy a whole new mount, can't just replace the stud. it costs about 50 shipped from gmpartsdirect.com look in the front suspension section, it's called a suspension mount.
when you tighten the bolt, ONLY SNUG with a 1/4" drive. those bolts snap like a hot knife through butter. any more than 10 ft/lbs and you're asking for trouble, even though the torque specs are 15 ft/lbs. i've broken 3 or them. trust me, use a 1/4" drive and as soon as you feel resistance stop.
Old Jul 21, 2008 | 05:41 PM
Dunkinuts's Avatar
yes the one in the engine bay. so you think i need a whole new mount? link? how hard is it to replace?
Old Jul 21, 2008 | 05:49 PM
D4u2s0t's Avatar
yes, you absolutely 100% need a new mount.
its not hard to replace, if you know how to do springs. you have to take the whole strut assembly off, compress the springs, take off the top damper nut, and the mount will come off. put the new mount on, put the damper nut, and de-compress the spring, then put the whole assembly back on the car.
here ya go, 42 dollars:
http://www.gmpartsdirect.com/catalog/frameset.cfm
didn't work for the link... go to gmpartsdirect.com, click on catalog, and put in your car info. then click on "Front Suspension" then click on "Suspension Components" then click on "Strut Mount". that's what you need.
Dunkinuts's Avatar
Strut mount Back 05-08 $71.11 $42.16 ????
Old Jul 21, 2008 | 05:51 PM
D4u2s0t's Avatar
yep that's the one. and like i said, be SUPER careful about tightening the nuts this time
Old Jul 21, 2008 | 05:52 PM
Dunkinuts's Avatar
now does that come with everything i need to replace it? the three bolts and nuts?
Old Jul 21, 2008 | 05:54 PM
D4u2s0t's Avatar
the studs are mounted into the mount. when you take the mount off, you'll see why it can't be replaced.
only thing you will need is the nuts, and you can re-use the ones you have now.
besides basic hand tools for the install, you'll need a set of spring compressors, and an impact gun or air tools will be a HUGE help for getting the top damper nut off. if you try taking it off with a regular wrench the whole strut will just spin.
Old Jul 21, 2008 | 05:56 PM
Dunkinuts's Avatar
well i think i lost one of the nuts but the thing is, the broken part of the stud/bolt i have but it was the front of the three studs/bolts that mount the strut.
Old Jul 21, 2008 | 05:58 PM
b_faulk75's Avatar
Should be the strut mount but for the front. Don't know why it says strut mount back, that's stupid, it is showing a picture of the front suspension. If you click on the second link that says suspenion components, it just says strut mount.
Old Jul 21, 2008 | 06:05 PM
D4u2s0t's Avatar
i could have swore i had a few extra nuts laying around, i just checked in my toolbox in the car and couldn't find any. i'll check at home later, and let you know if i have any. if so i'll let u have them. i know i had a few, but just not sure where they are.
Old Jul 21, 2008 | 06:08 PM
Dunkinuts's Avatar
thanks so how are the bolts in the mount? i have the bottom side of the bolt but not the side that the nut goes on.
Old Jul 21, 2008 | 06:13 PM
i can sell you a new top mount cheap thats easiest at this point doncha think?
Old Jul 21, 2008 | 06:14 PM
Dunkinuts's Avatar
I really don't think you could get cheap enough, i am not a fan of buying from people.
Old Jul 21, 2008 | 06:16 PM
D4u2s0t's Avatar
it's all welded together.
Old Jul 21, 2008 | 06:20 PM
Dunkinuts's Avatar
so we broke a weld and the bolt?
Old Jul 21, 2008 | 06:21 PM
2.4SlowassBalt's Avatar
reading the convo... i suggest that you take this to a shop... working with springs/struts is very dangerous and should not be done unless you fully understand what you are doing.
D4u2s0t's Avatar
now i'm confused...
Old Jul 21, 2008 | 07:48 PM
Dunkinuts's Avatar
the bolt broke in half. the front bolt that connects the strut to the body of the car.
ok i am up loading pictures as we speak
Old Jul 21, 2008 | 09:36 PM
uneed a new part....
Old Jul 21, 2008 | 11:36 PM
Dunkinuts's Avatar
but do i need a bolt or the whole upper mount?
