Struts and Shocks
Old Jan 10, 2015 | 06:46 AM
erockxp's Avatar
Smile Struts and Shocks
I am wondering if there are any non adjustable struts and shocks for use on lowered vehicles. Konis are way out of my price range and I figure non adjustable will be a bit less expensive. Any advice?
Old Jan 10, 2015 | 06:48 AM
umrdyldo's Avatar
Just get stock LNF parts
Old Jan 10, 2015 | 07:33 AM
Mr.Tozzi's Avatar
stock lnf or kyb
Old Jan 10, 2015 | 08:00 AM
erockxp's Avatar
So the stock LNF parts hold up well? KYB said their G series is not meant for lowered cars?
Old Jan 10, 2015 | 08:14 AM
umrdyldo's Avatar
Stock LNF stuff holds up fine.
Old Jan 10, 2015 | 12:50 PM
Why not get rear konis and front lnf? Thats the way im running atm since it takes a bit more work to install the fronts since they are inserts.
Old Jan 10, 2015 | 01:06 PM
erockxp's Avatar
Where can you get ahold pf lnf suspension parts?
Old Jan 10, 2015 | 01:13 PM
Cobalt - Ion - Struts, Shocks and Components
Old Jan 10, 2015 | 02:02 PM
erockxp's Avatar
Thank you sir!
Old Jan 10, 2015 | 02:06 PM
erockxp's Avatar
What is the difference between my FE3 setup and the FE5 setup?
Old Jan 10, 2015 | 03:19 PM
Coballin13's Avatar
Fe5 is lower
Old Jan 10, 2015 | 06:21 PM
erockxp's Avatar
Originally Posted by Coballin13
Fe5 is lower
Oh ok I thought it was the larger diameter wheels that made it look that way. Thank you!
Old Jan 25, 2015 | 04:57 AM
erockxp's Avatar
New information reveals that the FE5 suspension is in fact not lower..........Is this correct?
Old Jan 25, 2015 | 09:27 AM
blueLNFftw's Avatar
The springs are
Old Jan 25, 2015 | 11:00 AM
RyBread761's Avatar
I got my Koni yellows for $45 a piece on Amazon. I jumped on that quicker than a pig on ****.
Old Jan 25, 2015 | 11:05 AM
You got them new for 45 bucks?
Old Jan 25, 2015 | 11:07 AM
nobody2u's Avatar
The FE5 is completely reworked from the FE3. Not necessarily much lower, but the rates are all updated for the LSJ and then again for the LNF.
Old Jan 25, 2015 | 11:01 PM
RyBread761's Avatar
Yes sir
Old Jan 25, 2015 | 11:06 PM
Wow thats an amazing deal, i have my fronts but need to buy the spare struts to cut or buy them from powell
Old Jan 25, 2015 | 11:09 PM
blueLNFftw's Avatar
Why spares?
Just buy some KYB on eBay to cut.
Or snag stock ones off of Facebook from some stance retard.
RyBread761's Avatar
Originally Posted by blueLNFftw
Why spares? Just buy some KYB on eBay to cut. Or snag stock ones off of Facebook from some stance retard.
Hahahaha
Old Jan 25, 2015 | 11:17 PM
Well i mean the whole thing where the spring seats and its attached to the knuckle since the koni fronts are inserts. i just need to go to a scrap yard and get some, cut those since if i screw up i wouldnt be able to drive if i use the ones on the car
Old Jan 25, 2015 | 11:19 PM
Ohh plus powell sells them PC yellow with all the hardware to install i would buy those if im to lazy to cut and do all that stuff lol
Old Jan 26, 2015 | 02:55 AM
Spawne32's Avatar
General rule of thumb is that struts and shocks are only designed for a set amount of travel, and that any time you lower the spring height, you reduce that travel. Coilovers are the only true way to maintain properly shock travel while lowering you ride. That being said, acdelco FE5 replacement struts and shocks are your best bet as an upgrade which they sell on rockauto.com . Just be sure to consider how low you are going, as even the FE5 struts can only handle so much lowering before the travel is reduced to the point where the strut becomes useless and ride quality suffers. All struts and shocks on cobalts are of exactly the same height and have exactly the same amounts of travel. Im sure powell would argue that the YYZ springs are probably the minimum recommended amount of lowering while maintaining acceptable travel of the shock/strut, and he would be right.
bigdeertz
Nov 17, 2016 09:41 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
