Stupid question..
Old Feb 19, 2008 | 03:08 PM
bi0hzrd51's Avatar
Stupid question..
Well to you all it probably is, but to me its not cause I am clueless on this. I just ordered a set of the Eibach Sportlines and am pretty sure I need shocks with it. I have a 2006 2.2l LT. So if I do need shocks what would be a good set to get. I looked in the how to section on the Koni but not sure I would be able to do those, are they hard? Is there any other types that could be used with out modification? Thanks for the help in advance.
Old Feb 19, 2008 | 03:12 PM
mkulrey13's Avatar
Koni's are the best and only strut out for the cobalt. THere really easy, just plan a day around doing them. You dont need struts right away, after a few months your stockers will give and you will need to buy some koni's. Personally i'd wait to buy struts unless you have the money now but dont install the fronts till your fronts let go since you gotta cut them apart anyway.
Old Feb 19, 2008 | 03:14 PM
redlineblueline's Avatar
buy some ss/sc struts from crate engine depot
Old Feb 19, 2008 | 03:24 PM
bi0hzrd51's Avatar
So the stockers will be able to handle that kind of a drop? I just wondering cause I havent seen many non ss/sc talking about dropping theirs, and staying with the factory struts.
Old Feb 19, 2008 | 06:48 PM
montecarloman's Avatar
The factory FE1 suspension will not like the 2.5" drop the sportlines provide. I replaced my FE1 parts with FE5 struts and shocks. Had them on for almost a year now and have not had any problems. I don't like the Konis because they are inserts not struts. Just don't like cutting up perfectly good parts is all.
Old Feb 19, 2008 | 09:35 PM
bi0hzrd51's Avatar
Where are the FE5 availible and cost?
Old Feb 19, 2008 | 10:13 PM
crate engine depot they are a vendor here
Old Feb 19, 2008 | 10:18 PM
Cobalt30's Avatar
i have 60k miles on my car 50k w/ sportline drop. my struts are now finally wearing out in the front . so theres no rush man. but konis ftw
Old Feb 19, 2008 | 11:01 PM
bi0hzrd51's Avatar
And you have a base LS/LT? Cause Im just making sure I dont F' nothing up.
And for the FE5 from Crate Engine Depot what parts would I need if someone doesnt mind helping with that
Old Feb 20, 2008 | 03:23 PM
Really all you need are the front struts and rear shocks. only other part work getting is the front swaybar but it requies some modification to make it fit.
Tupp
Sep 29, 2015 11:07 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
