Suspension Problem!!!!!
Old Dec 5, 2006 | 12:05 PM
CobaltSS[303]'s Avatar
Question Suspension Problem!!!!!
Ok, one day i was driving and my car started to make a thumping noise in the back right suspension. it felt exactly like a flat tire. i got out and no flat tire. and i kept driving after that and it kept popping. then a few days later it stopped. and now the right rear sits like a 3/4 inch higher than the left rear. Do you know what this could be? and the tire sticks out a tiny bit but enough to notice it. but it drives fine. Just woundering what the problem with it is. Any help would be very much appriciated.
Old Dec 5, 2006 | 12:12 PM
Ljavy17's Avatar
I think your spring is mounted, Check the srping and make sure its in the hole its soppouse to be in.
Old Dec 5, 2006 | 01:00 PM
Halfcent's Avatar
I'm old school
Somethin' broke. Check the twist beam axle for impact damage. Check the Shock to see if it's froze up. Check the spring seat buckets.
Old Dec 5, 2006 | 01:12 PM
This is a few pics of the suspension comparison
Left Rear
Right Rear
Old Dec 5, 2006 | 01:14 PM
DWK5150's Avatar
Id look for a crcked spring.
Old Dec 5, 2006 | 01:23 PM
ok i will. do you think drifting could have done this? i was planning on buying new springs this week. the Eibach Sportlines
Old Dec 5, 2006 | 01:28 PM
06blackg85ss's Avatar
umm... yeah... you shouldn't be "drifting" a front wheel drive car. period.
Old Dec 5, 2006 | 01:31 PM
well ill look at it. im just hoping its not something else cause when i get my new springs put on i dont want it to sit higher i want it be perfectly even. which springs you think i should go with. im thinking the SSC springs or Eibach Sportlines. im going for a lower drop.
Old Mar 4, 2007 | 03:20 PM
BLK06SC's Avatar
anyone ever find out what the problem was i have this same prob rite now
Old Mar 23, 2007 | 12:40 AM
Drag-Sargeant's Avatar
Your spring may have jumped out of position?
Old Mar 23, 2007 | 06:59 AM
so how would you fix this? and sometimes i hear a rubbing noise when im going at slow speeds in heavy traffic.
Old Mar 23, 2007 | 11:01 AM
kissmySS's Avatar
Im experiencing the same symptoms and i DO NOT drift... lol
Old Mar 23, 2007 | 11:44 AM
see cause it kinda sounds like the rotor rubbing with the break but there fine. brand new. so i dont know what to do.
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
