Sway Bar Choices?
Old Feb 23, 2010 | 12:44 AM
StrongIslandBalter's Avatar
Sway Bar Choices?
Okay so I decided to buy a sway bar, and now has come down to which one. I know some arr stiffer then others so, whats the best choice? (rear sway bar)
Old Feb 23, 2010 | 12:47 AM
ls1fbody's Avatar
Haz l33t wheelz.
What is your intended use?
OTTP Street and Hardcore bars are the best options.
Old Feb 23, 2010 | 12:49 AM
well what do you mean intended use. Iam not looking for any severe suspension with the car. I have no intentions on coilovers, or springs..just figure I throw a rear sway bar on for a little edge on handling. Other then that all i have is a strut bar. btw i had eibach on my mind just becasue I know they are very involved in suspension
Old Feb 23, 2010 | 12:51 AM
ls1fbody's Avatar
Haz l33t wheelz.
Eibach is good, but not all that impressive. Stick with the OTTP Street bar, and you'll be set.
Old Feb 23, 2010 | 12:53 AM
okay thanks for the help :O). so just out of curiosity whats the difference like what would i feel between them diffrently?
Old Feb 23, 2010 | 12:55 AM
ls1fbody's Avatar
Haz l33t wheelz.
Between the two ottp bars?
Well, the Street bar is more mild, and creates a neutral feel. The Hardcore bar is more aggressive, and adds a bit of oversteer. THe Hardcore bar is meant for autocross, and the Street bar for some twisty spirited back-roads driving.
Old Feb 23, 2010 | 12:56 AM
so would i be stupid if i bought the hardcore? and i meant between the eibach and the ottp hardcore
Old Feb 23, 2010 | 12:59 AM
ls1fbody's Avatar
Haz l33t wheelz.
No, not stupid, but it's intended for more aggressive use with performance springs, and super grippy tires. And difference between the Eibach and OTTP Hardcore? Eibach is 25mm and OTTP is about 31mm.
Also, the OTTP rear bar is hollow = lighter. Not sure if the Eibach is or not.
Old Feb 23, 2010 | 01:00 AM
1badBlueberrySC's Avatar
I have the street OTTP bar on my TC... and ****** LOVE IT. The change it makes to the feel of the car in the twisties is nuts.
The hardcore bar is a bit much for a DD car... unless you want it... but no there is nothing wrong with buying it but if you don't need it you don't need it
Old Feb 23, 2010 | 01:09 AM
alright well i guess ill spend the extra and get the ottp street over the eibach. i guess nobodys gunna defend for eibach haah
Old Feb 23, 2010 | 01:12 AM
ls1fbody's Avatar
Haz l33t wheelz.
The OTT bars were designed by the man who built the Time Attack car for GM. If we don't listen to him, who else?
Old Feb 23, 2010 | 01:18 AM
caddiondubs's Avatar
what about the turbo tech racing bar. i have it and love it, its 25mm solid.
Old Feb 23, 2010 | 01:22 AM
ls1fbody's Avatar
Haz l33t wheelz.
solid doesn't make it better. The metal furthest from the center does most of the work, so hollow, being lighter, makes solid obsolete.
Old Feb 23, 2010 | 09:09 AM
northvibe's Avatar
honestly the hardcore bar is that...if you arent going to race on a track or some serious autox I wouldnt recommend it. I have it and did a autox and some street stuff...if you are an inexperienced driver you will whip a 180 easy. The street bar is the perfect solution for a DD or anyone that just wants better handling, honestly.
Old Feb 23, 2010 | 09:37 AM
Terminator2's Avatar
I have the street bar and I love it. I am probably going to get the hardcore bar as well for track use.
Old Feb 23, 2010 | 12:53 PM
G11's Avatar
G11
i have the eibachs front and rear and the difference over stock is amazing! if everybody says the ottp is better i wonder what they feel like?
Old Feb 23, 2010 | 09:52 PM
tru2nrtt777's Avatar
Not just that but you also need to look at the metal composition, ottp and eibach are chromoly, ttr is mild steel.
Why did you take your stock bar off? You do realize your stock front bar is better than eibach right?
Old Feb 24, 2010 | 01:22 AM
G11's Avatar
G11
nah i didn't but the handling and steering feel so much more stiff since i put them in
Old Feb 24, 2010 | 04:28 AM
mrsilent13's Avatar
i have both eibach bars...and since i installed them...my baby handles like its on rails....its very predictable compared to stock
Old Feb 24, 2010 | 05:29 AM
Menace Kustoms's Avatar
Very slow rails. Like the rollercoasters at the fair, lol!
Old Feb 24, 2010 | 08:10 AM
Boosted_Cobalt09's Avatar
ottp street bar is good for your daily driver that will increase handeling.
ottp hardcore bar is fine for driving but it does cause some over steer. their are ways to fix that though. running stiffer springs in the front, running so positive caster(not camber), lower tire pressure(when your racing) etc. regardless of your bar choice you always want the car feeling as tight as possible but to have nuetral feeling from both the front and back end.
Old Feb 24, 2010 | 09:24 AM
I have never driven a car with the eibach front bar but most have said it causes the car to understeer worse than stock. It seems like most that race their cars that have tried the eibach front bar have promptly taken it off because of the self steer and understeer they have experienced. Self steer is when the car is unevenly loaded from side to side and the steering wheel turns on its own.
Old Feb 24, 2010 | 12:01 PM
G11's Avatar
G11
ya mine doesn't do that lol
Old Feb 25, 2010 | 01:18 PM
SSSC's Avatar
I have an 06 sc cobalt and I got a deal on the eibach front and rear sway bars. I was planning on putting sportlines on with it. Should I not install the front sway bar, is the stock one stiffer?
Old Feb 25, 2010 | 09:14 PM
The stock FE5 is stiffer.
