Sway Bar Clunk
Sway Bar Clunk
Under braking, a clunk sound occurs from the sway bar hitting on the control arm. Struts were replaced, and noise still exists - any suggestions on what is causing the sway bar to hit control arm?
sway bar bushings shot, you have an 06 and the sway bar clamps are a tab with one bolt, and yield, upgrading to a two bolt fixing would be better. AND/OR you have an LT with FE5 short drop links which wont work.AND/ OR your trailing cabs are shot. 2 out of the 3 is my guess, dont think u have short drop links.
DANRICKARD
Oct 1, 2015 12:08 AM
