Sway Bar Clunk
Old Jul 1, 2012 | 08:38 PM
theflyinp's Avatar
Sway Bar Clunk
Under braking, a clunk sound occurs from the sway bar hitting on the control arm. Struts were replaced, and noise still exists - any suggestions on what is causing the sway bar to hit control arm?
Old Jul 1, 2012 | 08:59 PM
Powell Race Parts's Avatar
sway bar bushings shot, you have an 06 and the sway bar clamps are a tab with one bolt, and yield, upgrading to a two bolt fixing would be better. AND/OR you have an LT with FE5 short drop links which wont work.AND/ OR your trailing cabs are shot. 2 out of the 3 is my guess, dont think u have short drop links.
Old Jul 1, 2012 | 09:34 PM
nhanson's Avatar
So I put MOOG short links on my FE1 sway bar (nuts rusted so had to replace) with FE5 struts. Is that bad?
Old Jul 1, 2012 | 09:40 PM
short drop links may cause sway bar to crash into steel lower control arm under braking due to lack of clearance. Alloy control arms have more clearance (shape/ curvature )
Old Jul 1, 2012 | 09:43 PM
nhanson's Avatar
I had some noise like that but hasnt done it anymore...happened over bumps
Solaris99
28
Mar 15, 2017 01:22 PM
SSLOW06
Oct 1, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
