Sway bars
Old Jan 15, 2010 | 09:19 PM
koch1ar's Avatar
Sway bars
I'm thinking about getting sway bars on my car. I have SS/SC springs I'm gonna put on first and then I want to tighten it up a little. I heard that the SS/TC is good for the front, but would it be cheaper to get a full kit? No tracks just want to get rid of my body rollz. Whats the best bang for the buck? I have about $200 to spend.
Search button has too many unrelated threads and no definite answers in those on topic
Old Jan 15, 2010 | 10:01 PM
Maven's Avatar
Search has all the answer you just arent looking hard enough
SS/SC front bar and OTTP Street bar.
Old Jan 15, 2010 | 10:08 PM
HB_SS/TC's Avatar
I just so happen to have a silver TTR rear sway bar for sale
Old Jan 15, 2010 | 10:35 PM
G11's Avatar
G11
i got the eibach anti roll kit and have liked what it has done for stiffening up the ride! definately felt a difference around turns after installing it
Old Jan 15, 2010 | 11:59 PM
Fonzi1289's Avatar
Hey David hows that bar?
Old Jan 16, 2010 | 12:09 AM
HB_SS/TC's Avatar
Its pretty good only takes a couple mins to install
https://www.cobaltss.net/forums/parts-66/ttr-sway-bar-201252/
Old Jan 16, 2010 | 08:05 PM
Boosted_Cobalt09's Avatar
ss/tc bar and hardcore bar from ottp for me
Old Jan 16, 2010 | 09:23 PM
koch1ar's Avatar
https://www.cobaltss.net/forums/showthread.php?t=201252
yeah i saw your thread, but I'll need a front sway bar too when I install a rear
Old Jan 17, 2010 | 07:10 PM
OBZ's Avatar
OBZ
I have an extra set of bushings needed to swap the FE5 bar into an LS/LT. If amyone needs a set let me know. I bought an extra set..
Old Jan 18, 2010 | 06:51 PM
koch1ar's Avatar
i read that mounting locations changed slightly between the years so I'm looking for an 09 FE5 but can only find an 08 and under. Would that work?
I guess this is it http://www.crateenginedepot.com/stor...P1661C188.aspx Right?
Do i need the end links too?
Check your PM box OBZ
Old Jan 19, 2010 | 01:06 AM
Maven's Avatar
What changed on the SS/TC bars was the position/angle of the endlinks mounts. This doesnt affect its use any year car or its use with any model endlink, only the way it works.
You only need endlinks if you want a stiffer front. The stock endlinks will work but since they are longer than FE5 links they offer a slightly less stiff antiroll efect.
Old Jan 19, 2010 | 01:08 AM
ls1fbody's Avatar
Haz l33t wheelz.
you won't need a front, the stock bar has a perfect blend of stiffness and flex, there really isn't an upgrade.
Old Jan 19, 2010 | 02:00 AM
Maven's Avatar
I think hes got an FE1 car. Front upgrade is necessary for proper balance.
Old Jan 19, 2010 | 02:02 AM
ls1fbody's Avatar
Haz l33t wheelz.
oh, good catch, my badzz.
Old Jan 19, 2010 | 01:25 PM
G11's Avatar
G11
that sway bar i got you work out ok?
Solaris99
28
Mar 15, 2017 01:22 PM
SSLOW06
Oct 1, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
