View Poll Results: whats better solid or hollow sway bars
hollow bar
27
84.38%
solid bar
15.63%
Voters: 32. You may not vote on this poll
sway bars solid vs hollow
Hollow, material is more effective the further out from the center it is placed, in solid bars the inner material does not contribute much to overall torsion resistance.
Max torsion resistance:
Solid Cylinder Shaft: (pi/16)*max_stress*D^3
Hollow Cylinder Shaft: (pi/16)*max_stress*(D_outer^3 -D_inner^4/D_outer)
So for the same diameter and same material, solid shafts will have a higher torsional resistance by the factor of pi/16*max_stress*D_inner^4/D_outer over a hollow shaft. However the hollow will be significantly lighter, you make more efficient use of the material, thus for a given torsion resistance desired hollow shafts will be lighter.
Solid has more torsional rigidity. Hollow is not far behind, and is lighter.
A hollow 1.25" bar with a wall thickness of .25 would be the same as a 1.207" solid bar, although it would weigh much less.
DANRICKARD
Oct 1, 2015 12:08 AM
