Is there a Brake Conversion Kit out for the 2.2's
Old Apr 25, 2007 | 11:34 AM
7Thirty's Avatar
I wanted to see if there was anything out for the 2.2's to do a brake conversion for the rear of our cars. Anybody know of anything out there??
Old Apr 25, 2007 | 11:38 AM
KapnKirk's Avatar
I am looking for the same thing.... Those rear drums brakes are UGLY!!!!!!!!!!!!!!!!!
Old Apr 25, 2007 | 01:04 PM
Halfcent's Avatar
I'm old school
SSBC. WilWood has put brakes on a Cobalt, but they don't have a "kit".
Old Apr 29, 2007 | 07:46 PM
pjk91's Avatar
whats the bolt pattern on the 2.2's? i bet i could find a way to do it...
Old Apr 29, 2007 | 07:55 PM
mkulrey13's Avatar
4x100
Old Apr 29, 2007 | 07:56 PM
biniecki's Avatar
did any of the cavi's come with all wheel disc?
Old Apr 29, 2007 | 10:55 PM
denn454's Avatar
cavilers were all 5 lug wheels... some junk yard parts off an LT is all you need. i would imagine it would be a fairly simple swap.
Old Apr 29, 2007 | 11:03 PM
bluebaltjim's Avatar
check turbo tech racing in the vendors section
Old Apr 30, 2007 | 08:00 AM
xspyder85x's Avatar
yeah they have a kit i think its $999 but im going to look for a LT
Old Apr 30, 2007 | 01:12 PM
pjk91's Avatar
didn't realize the LT's came with discs, but i found one today and sure enough, it had discs. do the LT disc swap. Integra Type R uses a 4x100 bolt pattern too, and they have decent brakes...fyi.
Old Apr 30, 2007 | 05:17 PM
biniecki's Avatar
Just out of curiosity what is involved in doing a conversion such as this? If its not to hard I may look into doing this as well.
Old May 1, 2007 | 04:34 PM
Blankobalt06's Avatar
LT? I have a LT and no rear dics.
Old May 2, 2007 | 02:42 PM
scotty1979's Avatar
Brake Specialists here n Austin said they would do it for about 1500 to 2500. so its possible lol
Old May 2, 2007 | 02:53 PM
GardellaRacing's Avatar
we grafted a wilwood brake kit from a TC to fit our street car.
Old May 2, 2007 | 03:05 PM
07cobaltowner's Avatar
i have done a rear disc brake conversion, as long as the hub is the same it will swap over. the brake lines usually use the same type of connection before they go to the caliper or drum and it shold only take 2 hours at most. you don't need to have it done you almost can't screw it up unless you don't know anything about brakes (bleeding the line etc...) make sure to have an alignment done afterwards though!
i am hopefully going to do this soon. if i do i will make a how-to:
Old May 2, 2007 | 03:36 PM
scotty1979's Avatar
thanks can't wait to read the how to. Put parts needed also
Old May 2, 2007 | 03:42 PM
cheesetits's Avatar
The Saturn SC2 has the same bolt pattern as the cobalt. (4x100). Check out http://www.saturnmotorsports.com/ they have a kit for it.
http://www.saturnmotorsports.com/cat...roducts_id=447
I don't know if it will fit but maybe you can look into it.
Old May 2, 2007 | 04:13 PM
denn454's Avatar
why do you need an alignment? you aren't messing with any thing that would change the alignment, and there is no adjustment in the rear that i've seen.
Old May 7, 2007 | 11:53 AM
KapnKirk's Avatar
Yeah I have an 07 LT and I have Drums in the back... Looks so ugly to me!!!!
Old May 9, 2007 | 03:14 AM
bridfi's Avatar
ive been looking everywhere also, i want bigger discs all around... the brakes lock up too easy im afraid ill hit someone soon. they've already locked up on me like 4 or 5 times (no ABS) so im thinking of getting the kit: http://www.saturnmotorsports.com/cat...roducts_id=447 will it work on the cobalt??
Old May 9, 2007 | 09:29 AM
pjk91's Avatar
If you get bigger discs, you aren't going to be able to modulate your brakes easier. You won't be adding ABS by adding larger discs and calipers. In fact, you will probably lock them up even more often with larger discs. You may want to take an aggressive driving course if you are really that concerned about locking up brakes with no ABS.
Old May 10, 2007 | 02:52 PM
bridfi's Avatar
i know that already, i am looking into how to install ABS
Old May 13, 2007 | 03:32 PM
pjk91's Avatar
In that case, you want an EBCM (electronic brake control module) and I don't know if that's all you need either.
Old May 13, 2007 | 03:41 PM
SymbioteLT's Avatar
06 LT, rear drums
Old May 14, 2007 | 09:11 AM
7Thirty's Avatar
What all would i need to order if i got the parts new for the LT disc swap.. i can probably get a discount on the parts so i would just need to know what all i need.
The SSBC conversion is NIIIIICE but if i can get away with NOT spending 1300 im all for it LOL
