Is there a Brake Conversion Kit out for the 2.2's
I got an 06 LT and have the drums... they are crap... I was thinking of painting them, and then thought about just doing the conversion myself... If it really is that simple I may do it. Anyone do a how to yet?
http://www.saturnmotorsports.com/cat...roducts_id=447 will it work on the cobalt?
LMFAO. He said she said.
THANK YOU!!!
THANK YOU!!!
Last edited by Blankobalt06; May 16, 2007 at 07:26 PM. Reason: Automerged Doublepost
if you buy this kit or any kit your rear brakes would look beefd up so you will need to upgrade your front brakes as well, so youre looking at a $2500 project.
im thinking donor parts from cars with factory rear disk brakes with 4x100 bolt pattern
http://www.gravanatuning.com/applica....2.aspx/3/3706
I have run these on several of our Gravana project cars and they work great!
Jim
im looking into this and was thinking
order aftermarket rear disc from a 4x100 car (manty many popular cars are 4x100)
need calipers
matching stainless braided brakelines for the calipers above (this would make sure i have the correct fitting for the caliper, are all brakeline to calipers the same?)
and to fabricate a bracket to mount these calipers (the hard part)
am i missing anything?
need calipers
need calipers
need calipers
I would rather buy something that has brackets that are designed for my car and a caliper/rotor/pad combination that is engineered to work for my car and it's size and weight rather than rigging something. After all, it is my brake system.
Then again, it does get exciting when your brakes fail diving into turn 11 at Sears Point trying to drop from @ 120MPH down to @ 30MPH...
