Think these will fit?
Old Mar 13, 2010 | 01:01 PM
Wangspeed's Avatar
I'm tempted to try this for $30.
Obviously, you'll have to remove the rotor shield for full effect. From past experience, removing the rotor shield is a bit of a double edged sword if it's FWD or AWD. The heat from the brakes dissipates faster, but the CV boot is right there.
Thoughts? You'll need to register to see the pics on EvoM, but basically, it's Porsche GT3 brake ducts on an Evo X.
http://forums.evolutionm.net/evo-x-t...e-30-hour.html
http://www.planet-9.com/reviews/show...ct=180&cat=all
Old Mar 18, 2010 | 05:41 PM
Wangspeed's Avatar
I'm taking a gamble. Gonna try to make these fit. Will let you guys know. If it fits on the TC, it should work for anything with FE5 control arms.
Old Apr 11, 2010 | 09:28 PM
Wangspeed's Avatar
Welp, I tried to get these fitted today, and they seem to work, but I was a bonehead and put them like 1 pinky away from the rotor, uh, with the wheels pointed straight. They have "self-adjusted" themselves away from the rotor now though
The angle isn't optimal because it curves a bit towards the front of the car near the rotors. Ideally, it would stay straight. I may cut some off.
Got them paired with some Cobalt XP1 pads for VIR next week. John, where's that bar
Old Apr 12, 2010 | 08:26 PM
chitala383's Avatar
ummm... that looks sooo ghetto. i wouldnt trust that with zip ties
Old Apr 12, 2010 | 08:47 PM
Wangspeed's Avatar
If I have an off track excursion, I'd rather the zip ties break and lose the ducts rather than break something else in the area. I also want to be able to quickly remove them if it's a rainy event.
Old Apr 13, 2010 | 11:39 AM
F_Imports_09tc's Avatar
Hmm, good to know. For 30 bucks even if they break off its not a huge loss. Easy removal with the zip ties is also nice. Let us know how they work and how much of a difference in brake fade, feel, etc you feel.
OP, where do these spoilers direct the air? Is it into the center of the rotors near the hub, or just the inside face of the rotor itself? Thanks.
Last edited by F_Imports_09tc; Apr 13, 2010 at 11:39 AM. Reason: Automerged Doublepost
Old Apr 13, 2010 | 11:48 AM
haymakercobalt's Avatar
Good point.
Old Apr 13, 2010 | 12:08 PM
rallyracer's Avatar
Brake cooling kits direct the air onto the inside face of the rotor....
As you can see here \/
Old Apr 13, 2010 | 12:24 PM
Wangspeed's Avatar
Ideally, you send air to the hat where the air travels from the center to the outside, but we have this annoying thing called FWD, so some crap gets in the way I may trim the duct a bit this week. I'll try to get some better pictures when I do.
Old Apr 13, 2010 | 12:31 PM
rallyracer's Avatar
If you willing to spend the money...we have a someone who you get you 2pc rotors and set you up with a decent brake cooling kit.
You know you to contact if interested .......................................\/
Old Apr 13, 2010 | 07:00 PM
2 piece rotors + brake cooling would be sick. Wish I had the money for those goodies. Rallyracer, is that your setup with the KW coilovers and brake cooling? If so I'm jelous.
Old Apr 13, 2010 | 09:13 PM
rallyracer's Avatar
I'll be running the koni race brakes (2pc rotors) this summer...maybe by fall I pick up the brake cooling kit.
Those are not pics of my setup but the Pedders springs, TC struts and shocks along with some fun Powell parts that I run are awesome!
Old Apr 14, 2010 | 01:01 AM
jboogie's Avatar
I haven't had any brake fad yet with this car on stock pads. But may 1-2nd will be my first trip on the new sticky tires to Carolina Motorsports park. A very brake heavy track. So, we'll see. If that happens, thinking of fabing up some cooling ducts using the factory fog light holes
Old Apr 14, 2010 | 11:04 AM
Wangspeed's Avatar
The factory fogs aren't a good candidate for ducts. I looked, but they're too far to the outside of the car to be of any use. Way too severe of routing to make it work, unless you use an electric blower.
CMP was where I had my first race years ago. I hear they've changed the last few turns of the course so it's no longer miserable 2nd gear, tire eating, brake destroying crap. Oh, and the gator strips leading to the front straight will rip suspension out of alignment. Kershaw is a sandy, hot ass place, with no shade, and angry ants. The only trees around are the ones that people somehow manage to hit. Then there's the Executioner, err, Executive Inn, where they steal your drinks if you don't lock them up. On the plus side, there's the nightly entertainment out on Hampton street. Just sit outside and watch. But don't mind my rant. It's still better than going to work
Here's some in car footage from the old version of CMP. Sorry about the small video, but I don't have the original anymore. The first half of the track up to the high speed kink is actually pretty fun. Miserable after that.
http://bit.ly/bquAud
Old Apr 14, 2010 | 11:14 AM
jboogie's Avatar
HAHA I love the Executive inn. Probably cause my GF refuses to go back there? And by entertainment do you mean watching people trying to parallel park? Cause in Kershaw people just can't seem to figure it out. CMP is crap compared to VIR but, it's just so cheap! Running there with my first event with NASA (HPDE 1 ) for $250 for the entire weekend!
Thanks for the info on the fogs, I haven't done much research. It was just a thought at this point.
Anyway, let us know how this works out for ya.
hacadacalopolis
Oct 28, 2015 06:09 PM
cavfiredesire
Oct 3, 2015 08:02 PM
jmelton327
Wheels and Tires
Oct 2, 2015 01:54 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Delta coupe
Sep 30, 2015 08:11 AM
