Track control on 2.4L SS
Old Dec 3, 2005 | 01:55 PM
G4_mexico's Avatar
hello guys,
is there any way, to create a sort of switch that bridges the track-control fuse.. to create an On/Off switch?
Old Dec 3, 2005 | 02:02 PM
celicacobalt's Avatar
i wish, the only way to turn it off right now is put it in L
Old Dec 3, 2005 | 02:22 PM
G4_mexico's Avatar
mm not quite. Mine has a 5 speed manual gearbox (Getrag)
Old Dec 3, 2005 | 02:27 PM
Clmbngfrk18's Avatar
well if there is a specific fuse for trac control all you would really have to do is a wire ,preferably the live side, from off the fuse cut it and splice in a switch not hard but thats if there is a dedicated fuse
edit i was confused before but now i get it the manual trans mission doesnt have trac control most you might have is a lsd why are you having problem spinning the tires
Old Dec 3, 2005 | 02:52 PM
RaineMan's Avatar
The manual has Traction Control?
Old Dec 3, 2005 | 04:05 PM
there is only a tranny fuse in mine i looked for a trac specific fuse but no luck
my bad, for man i didnt know they had trac control
Old Dec 3, 2005 | 05:58 PM
97cavie24ls's Avatar
as far as i know the cobalt 5spds dont have trac control , only the auto's have it
it must be a mexico thing
Old Dec 4, 2005 | 12:55 AM
mi6_'s Avatar
The autos have it because it is not really traction control. If severe wheel slip is detected in 1st gear, the tranny shifts into second (less torque). Thus, the manuals don't have it.
Actual traction control woul reduce the throttle, or apply the brakes or both. But these cars only have the lame upshift feature.
Old Dec 4, 2005 | 01:10 AM
detrini's Avatar
My auto doesnt shift into second, it reduces the throttle and the tires actually begin to stutter, like a stop and go action. I've had fun with it in the ice and snow so far.... You can put the car in 2nd and the T/c still works and it definately doesnt shift into 3rd.
edit: checked the manual, page 4-8..... read up, not "a lame upshift feature"
Old Dec 4, 2005 | 03:02 AM
mi6_'s Avatar
I could be wrong, but on the Cavalier thats how the system worked. I'd be surprised if the system was improved. If it was an actual TC system, it would be on the manual too like on the Corvettes!
If you put it in second and you have traction control that means nothing. If you select "2", that means the transmission can choose between only 1st and 2nd gear. So it could be shifting to 2nd and that is what you are noticing. Put it in 1st and see if you have traction control. If you do, then it is an actual traction control system, not simply an 1-2 shift like I think it is!
Old Dec 4, 2005 | 03:15 AM
detrini's Avatar
traction control is off when you manually select 1st gear on the autos...... It is still on when you select 2nd gear and reduces the throttle.... If its just in drive and you floor it from a stop the wheels begin to break loose the t/c kicks in and reduces the throttle until the wheels grip again. Thats it, no shifting gears, if your cruising along in like 3rd or 4th gear and somehow the wheels lose traction then yes the transmisson will shift while the engine reduces throttle in an attempt to regain traction, the cobalts share the same owners manual.... check the page..
Old Dec 17, 2005 | 03:41 AM
G4_mexico's Avatar
My bad, Indeed it doesn't have traction control. Since I got it, I didn't wanted to give is some extra gas... but it was inevitable a few hours ago... NO traction Control.=)
Old Dec 17, 2005 | 07:20 AM
denniss's Avatar
If you lift the parking brake handle one click it will defeat the traction control. I would just make sure the brake is not engaged on the first click or you will wear your parking brake out VERY quickly.(A lesson I learned the hard way 30 years ago!) Here is the page explaining how the system works for those of you that didn't read your owners manual.
Document ID# 1576393
2006 Chevrolet Cobalt
Enhanced Traction System (ETS)
Your vehicle may have an Enhanced Traction System (ETS) that limits wheel spin. This is especially useful in slippery road conditions. The system operates only if it senses that one or both of the front wheels are spinning or beginning to lose traction. When this happens, the system reduces engine power and may also upshift the transaxle to limit wheel spin. You may feel or hear the system working, but this is normal.
A LOW TRACTION message will appear on the Driver Information Center (DIC) when the traction control system is actively limiting wheel spin. Slippery road conditions may exist if this message is displayed, so adjust your driving accordingly.
If your vehicle is in cruise control when the Enhanced Traction System begins to limit wheel spin, the cruise control will automatically disengage. When road conditions allow you to safely use it again, you may re-engage the cruise control. See Cruise Control .
When the system is on, this warning light will come on to let you know there's a problem.
If the warning light stays on, or comes on when you're driving, there may be a problem with your Enhanced Traction System and your vehicle may need service. When this warning light is on, the system will not limit wheel spin. Adjust your driving accordingly.
The Enhanced Traction System warning light may come on for the following reasons:
• If you turn the system off by moving the shift lever to FIRST (1), the warning light will come on and stay on. To turn the system back on, move the shift lever back to a position other than FIRST (1). The warning light should go off.
• The warning light will come on when you set your parking brake with the engine running, and it will stay on if your parking brake does not release fully. If the transaxle shift lever is in any position other than FIRST (1) and the warning light stays on after your parking brake is fully released, it means there is a problem with the system.
• If the traction control system is affected by an engine related problem, the system will turn off and the warning light will come on.
If the Enhanced Traction System warning light comes on and stays on for an extended period of time when the transaxle shift lever is in any position other than FIRST (1), your vehicle needs service.
Adding non-GM accessories can affect your vehicle's performance. See Accessories and Modifications for more information.
Dennis
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
Extremespeed
Sep 29, 2015 04:34 AM
Coballin13
Sep 25, 2015 08:43 AM
