traction mods??
traction mods??
hey how can i drop my 0-60' time??? wut kinda mods can i get
i know of:
-ingalls torque damper
-traction bars(can u install without drilling??)
-eibach sportline springs(dont know if that will help tho)
i cant think of ne more offf the top of my head help me out guys
thanks
-cpraider12
i know of:
thanks
-cpraider12
-Better springs and struts will help TONS.
-Motor and transmission mounts, control arm bushings, and sway bar bushings and endlinks, if available, are all nice easy upgrades.
-Better tires obviously.
-I hear that torque damper is a good piece.
-Traction bars can be a TON of help but I think that 90% require some drilling at least.
hmmm. you want to go hard but cant because of wheel hop or spinning. ever think of tires? how about tires and rims?
He is my recipe to success. 17 x 9.5" rim wrapped in NITTO 555R's P245/45r17
Someone know where I would be able to get the rims from?
I think that you better to go with 15in with drag radial than going with 17 in imo
SS/SC's front brakes are too big for a 15", you canr get a 16" with some elbow grease and a grinder, file and sand paper.
tires are you main concern
i mean, yes, you could spend a lot of money on sway bars, struts, torque dampners and everything and you'd have a nice set up, but you can get the same job done with some nice tires
I will have gone from a 3.8" side wall to 4.6" and about an 1" to 1 1/4" wider. the Nitto 555R uses the same compound as their DR.
With this set up you can not doubt that traction will have greatly improved due to the rubber compound, sidewall height, and foot print of the tire. I am also set up for autocross and track days! which is what I want.
Originally Posted by cpraider12
and wut kind of tires do u guys suggest?? i mean ill jut be buyin two
can u send me a link of where i can get these tires??
I have BFG KDW2s and there work great!
I want to got a 17x8 or 17x 8.5 next year but I dont think a 17x9.5 will fit the car at all. that 2,5" wider then stock not 1.25 man.
I have 18x7.5s now and my tires have about 1" more ruber on the ground then stockers did.
Im geting 2.1 - 2.2 60' times but I think I can do alot beter. I think 2.0 - 1.9s can be had with street tires if track prep is good and the driver knows what hes doing.
Later
Later
The rims are 20lb each and the tires are the same as the stockers. So im saveing about 4lb each.
But Im having a problem with tred cuping on the 7.5" wide rim. They realy need to be on an 8" wide rim to get there best traction.
Later
Later
