Traction problems
Old May 13, 2008 | 08:07 AM
kyjaxskater's Avatar
Traction problems
i like everyone else probably has run into the traction and wheel hop problems of the 2.0 supercharged cobalt. i have just recently ordered a prothane transmission motor mount insert and a DC sports front strut bar. is there anything else besides coilovers that would help with the traction problem?
Old May 13, 2008 | 08:10 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Those black things with M/T written on them.
Old May 13, 2008 | 08:11 AM
zay52790's Avatar
USE DA SEARCH BUTTON!!!!
but seriously, a tourqe damper will help alot. Also, you did order two inserts right, for the front and rear tranny mount?.
Aside from that maybe traction bars for the wheel hop.
As for cornering traction, get some springs or coilovers and a rear sway bar. the rear sway will really help reduce the natural understeer the car has.
Old May 13, 2008 | 08:13 AM
Badju587's Avatar
TTR motor and tranny mounts + sticky tires (I'm moving up to BFG KDW's when the stock Pirellis finally go). Can't get any cheaper traction than that, coilovers are pretty pricey.
Traction bars might help a bit, but (correct me if I'm wrong), they help more with keeping the inside wheel planted when taking a hard corner. Motor and tranny mounts will help a lot, ever seen what our stock engines do in the bay when you got WOT?
EDIT: Geez, third post and there were none when I hit the "Reply" button. Man i'm slow.
Old May 13, 2008 | 08:14 AM
TRASH. I noticed NO difference in my car from having JUST Poly Trans Mounts... to having the Trans Mounts AND the Ingall's.
Once you have the Trans Mounts... get the Upper engine mount... and then there is no need for that gay little ETD.
If you are serious about your traction... you need to look at the BWoody's site... their ACTUAL Solid Mounts are the way to go. You won't need the traction bars with all three mounts... just a good, wide, sticky set of tires.
Old May 13, 2008 | 08:16 AM
Dead Zen's Avatar
i would def suggest KDW2's. i was at the track sat, first time with the KDW's. I had no hop and all i got is a poly motor mount. The BFG's just bite and hook man
Old May 13, 2008 | 08:20 AM
Jumpin Fool's Avatar
If you're talking about straight line traction...
Bwoody Solid Engine/Trans Mounts
Bwoody Traction Bars
But you can't be crying about the vibrations after you get them.
The ETD is garbage if you're looking to make a real difference.
Check my garage if you're interested in setting your car up for turns.
Old May 13, 2008 | 08:21 AM
nuttzzy's Avatar
if your going to go this far as far as mounts and sticky tires might as well save for some axles also... trust me im there with the soild mounts and stick tires just no axles.
Old May 13, 2008 | 08:22 AM
Dead Zen's Avatar
meh. you only need axles if your a moron. there are a few examples of big whp cars on stock axles, and clutches too
Old May 13, 2008 | 08:24 AM
Question
Explain
Old May 13, 2008 | 08:32 AM
Dead Zen's Avatar
well. getting on it with the wheels turned. really dropping the clutch at high rpm. paul, i forget his name on here. but he is making 411whp, stock clutch and all
Old May 13, 2008 | 08:34 AM
It is Sudden Shock that snaps axles... not power.
Wheel Hop is a BIG killer.
Old May 13, 2008 | 08:40 AM
Dead Zen's Avatar
ty. tis the truth. dunno why i couldnt say that. prolly the vicodin for the bad foot
Old May 13, 2008 | 08:43 AM
Just because somebody is doing it doesn't mean that it's right or it's going to last.
I've had traction mods on my car for a long time now and haven't had wheelhop since I bought the car but recently cracked the tranny housing somehow. I don't do either of what you mentioned and I'm well aware of how to drive. GM believes the problems can be averted by beefier axels.
So, instead of flapping your face with simple stupid name calling, try making intelligent statements based on facts/experience. Not something you heard that somebody's monkey's brother's sister's grandma's ex-lover's dog did.
Old May 13, 2008 | 08:48 AM
nuttzzy's Avatar
This is true it is the " Sudden Shock" that snaps them NOT!!!!!!! I personaly know someone that was makeing a right turn at a light and was going 20 mph when his cv joint broke on his STOCK CAR not even an intake, and if you wanna say its the sudden shock if your running a racing clutch "like me" and a bunch of other people on this threw you do get more power going to the joints even with a stock motor for the simple fact it grabs better and quicker with no slip
....Now Who's a Moron? I think that a harsh word for someone that clearly hasnt broke an axle yet.
Old May 13, 2008 | 04:21 PM
TurboTechRacing's Avatar
You really need a solid engine mount to prevent wheel hop, then a good set of tires to "hook up"
Chech out the Turbo Tech Racing Engine mount...
Old May 13, 2008 | 04:38 PM
I can't understand your ****** post. You need to learn to use a Period. That one massive sentence makes my head spin. Either way... using your theory here, if one person has his break making a turn at 20 mph... that means that they are all junk? My car puts down over 270whp now... and I haven't popped an axle. Been to the track quite a few times as well.
That's one of the stupidest statement that I have heard in a while. Almost as dumb as the guy that says our stock clutches suck... because his went out at 2,000 miles. Of course, he failed to mention that it went out because his Slave Cylinder busted and filled the Bellhousing with Brake Fluid... effectively ruining the clutch.
And putting in a "Racing Clutch" isn't going to give you more power (to the wheels or otherwise)... unless your stock clutch is/was slipping.
Old May 13, 2008 | 04:57 PM
Dunkinuts's Avatar
is there a engine damper that fits the 2.4L? and where can i get some traction bars?
Old May 13, 2008 | 05:02 PM
Traction Bars can be bought from BWoody...
http://bwoodyperformance.com/
BWoody Performance Products
Old May 13, 2008 | 06:01 PM
nuttzzy's Avatar
sorry for the ******* grammer. I put in a racing clutch because my shitty stock clutch was slipping. I couldnt make it to the top of an overpass on the highway. Also I didnt say it made more power I said it grabs better and doesnt slip. As far as the Axles go Good for your 270 whp Machine with stock axles. But, if you read around plenty of people are having axel issuse including myself. So just cause yours have'nt broken dont assume they won't or arn't weak.
Old May 13, 2008 | 06:09 PM
InfinityzeN's Avatar
Stock clutch slipping? Simple fix. Learn to drive!
NGTFO
Old May 13, 2008 | 06:11 PM
I didn't say that you said it MAKES more power... I said, that you said it GIVES you more power "to the joints"...
Old May 13, 2008 | 08:49 PM
nuttzzy's Avatar
So whats your opinion on the axles and clutch. It shouldnt go out if your a wonderful driver like yourself?
Old May 14, 2008 | 06:08 AM
"If you ain't breaking ****... you ain't going fast enough."
The Axles are a weak point... but they shouldn't be popping with ANYTHING under 300whp AT LEAST.
And the clutch is rated at 400+hp. The problem with it, is that it is temperamental. If you don't drive it the right way... it'll hate you. I beat the living **** out of my car... 52,000 miles in 2 years (and I only put 4k on it in the last 6 months, I took it easy). I've probably WOT my car more in those 2 years... than you've ever WOT anything. I've roasted my clutch a few times... really bad too. But proper driving techniques for the clutch proved useful as it only took about a week for the clutch to start behaving normally again.
In fact, my clutch grabs SO hard when I shift during a race... that the whole car jolts and the CD player skips for a few seconds.
And it doesn't take a bad driver to pop an axle. It just takes one mistake. And there are numerous ways for it to happen.
I've seen a 275hp Eclipse break 400hp axles by making a simple mistake.
turbochargedss2012
Sep 20, 2023 12:17 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
