trouble decompressing rear piston
Old Mar 27, 2009 | 01:49 PM
harryresh's Avatar
im putting some Hawk HPS pads on and im having trouble decompressing the rear brake piston. it wont budge. i had no problem w/ the fronts so im assuming it has something to do w/ the e-brake? i tried removing the spring but still nothing. do I remove the whole e-brake bracket off of the end of the caliper?
Old Mar 27, 2009 | 02:15 PM
crt013189's Avatar
you need a special tool autozone or pepboys have them they are like 10 bucks the rears need to be turned in not compressed in
Old Mar 27, 2009 | 04:54 PM
lumbad's Avatar
i have heard the same thing. you are supposed to actually "screw" it back in. i think it has something to do with the e-brake, but i may be way off on that part.
Old Mar 27, 2009 | 07:03 PM
DaBuzzard's Avatar
Correct and correct. The rears screw in / out, this is to allow the e-brake to adjust. Would really suck if you had to keep pulling the handle higher and higher as the pads wore out
Old Mar 27, 2009 | 07:09 PM
Black SS/SC 06's Avatar
Hopefully you have the e-brake off
Needle nose pliers work too
Last edited by Black SS/SC 06; Mar 27, 2009 at 07:09 PM. Reason: Automerged Doublepost
Old Mar 27, 2009 | 08:13 PM
harryresh's Avatar
yes i had the e-brake off...thanks guys
Old Mar 27, 2009 | 09:03 PM
ok just checking, that could have been a problem lol. the rear is definitely harder than the fronts.
Old Mar 27, 2009 | 09:06 PM
eurochevy's Avatar
i did my brakes within the last 5 months or so.. do what hes saying..i think hes the one that suggested it to me in the first place lol it was either him or DOC... but yea..needle nose pliers..push down and turn clockwise
Old Mar 27, 2009 | 09:26 PM
Not sure if it was me or not, but regardless it works lol.
Old Mar 28, 2009 | 01:31 PM
css9450's Avatar
...push down and turn clockwise
One side is clockwise, the other side is counter-clockwise.
Old Mar 28, 2009 | 06:15 PM
Sharkey's Avatar
i just did mine an hour ago, they were both clockwise.
i found as well as needlenose pliers work, using a pair of regular plies is better, it doesnt want to slip off as easy.
Old Mar 28, 2009 | 06:19 PM
Well there are different types of needle nose pliers. So I guess it just depends on what the ends look like. Yea they should be clockwise to make them go in, I don't know what the other guy is talking about lol.
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
