Trouble reinstalling Koni struts
I've got the inserts all set back up, they just won't go back in the car nicely. The problem is the bolt that is now on the bottom of the strut keeps hitting the axle and limits where I can move it. If anyone knows the best method for getting these back in please let me know
As for getting the strut assembly back on the car, I loosen the rear control arm bolt. The big honkin bolt. I also loosen the front control arm bolts some if I'm having a tough time, but usually the rear is enough. Most people probably don't need to loosen them though. I do it because I have PRS bushings for the leading and trailing control arm bushings.
I never had a problem getting mine in and out, matter of fact I had both bolts back out a bit on me a couple of times with plenty of room. Try turning the wheel while supporting the hub unit to give you more clearance.
I've got both bushings replaced as well. I can get the top three in no problem and even get the knuckle in the strut bracket but once thats in the strut is too low to align those two bolts in. If I were superman and could simply compress the strut an inch that'd do the trick
Anyone know the torque specs for both bushings? I think the rears are 138 lbs
edit: success! Undoing the cabs did the trick perfectly
