Trouble removing lower strut/knuckle bolts? Am I missing something?
Old Sep 26, 2012 | 02:04 PM
Jesse's Avatar
Haha I have been trying to remove the two lower front strut-to-lower knuckle bolts for the past 45 minutes. I got tired of looking like a redneck in my parking lot and put everything back together. What the hell am I supposed to do with these things?
Old Sep 26, 2012 | 02:25 PM
BLAZIN07SS's Avatar
I'm too JDM for you
have to hammer them out
Old Sep 26, 2012 | 02:33 PM
Jesse's Avatar
I tried that haha. Maybe I need a B(igger)FH.
Old Sep 26, 2012 | 02:42 PM
OttawaMark's Avatar
One bolt I hammered for 2 hours before she finally gave in and could pull my strut off, just watch ur nut mine mushroomed pretty bad after all that mcloving.
Old Sep 26, 2012 | 02:44 PM
BLAZIN07SS's Avatar
I'm too JDM for you
PB blaster everything before trying again.
Old Sep 26, 2012 | 03:03 PM
dsmnutz's Avatar
PB blaster, impact wrench and BFH...in that order
Old Sep 26, 2012 | 03:07 PM
Jesse's Avatar
Thanks guys I'll have to try it next week. I'm out of time this week haha. My car will have to make do with only the rear springs changed until then.
Old Sep 26, 2012 | 04:24 PM
06cobalt racer's Avatar
yeah like they said you have to hammer them. this is what i do and it works every time:
1. take the nut off
2. turn the nut around so the the flat portion of the nut is on the outside
3. thread the nut on until the tip of the bolt is almost flat with the flat portion
4. give it some good hits with your hammer. i just use a regular hammer and it takes maybe 4-5 good hits.
5. hammer till the nut is against the shock
6.remove the nut and pull the bolt out.
7. do the same for the other one.
this always works for me. hope it helps
Old Sep 26, 2012 | 05:08 PM
07cobaltLScoupe's Avatar
you could always try to take some weight off the knuckle and then hammer the bolts out if they're that tight
Old Sep 27, 2012 | 02:34 AM
**** i forgot to put this step in too!!! yeah what they ^^said
DarrenGC
Dec 24, 2021 01:55 PM
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
CobaltSS 16
Sep 29, 2015 01:53 PM
