Trying to remove front springs. .
Old Jul 18, 2008 | 08:21 PM
Magnus's Avatar
And i cannot get this damn bolt backed out for anything. The bottom one won't move a bit either. Starting to make getting this strut out harder than it needs to be. . . what did everyone use to get these little bastards out????
Old Jul 18, 2008 | 08:23 PM
joeworkstoohard's Avatar
take off the nut, hit it with a hammer. it's a press in.
Old Jul 18, 2008 | 08:24 PM
BULLETSSMOKE's Avatar
smack it with a big ass hammer really hard. just be careful not to damage the threads. it just slides out
i find that it helps to put the nut back on so that it's flush with the end of the threads, gives you a better striking surface, and less likely to marr the threads all up. plus, it won't go flying.
Old Jul 18, 2008 | 08:25 PM
Magnus's Avatar
Thanks guys. I thought that might be what it was, but didn't want to get to hammering and end up stripping it.
Back outside in the 99*+ weather i go.
ItalianJoe1's Avatar
Just don't hit it so hard that you damage the threads. If you have to, put the nut back on before beating on it, but the end is pointed so you can wack it pretty hard without a problem. Grease them up when you re-install and line them up so they go in smooth.
Old Jul 18, 2008 | 08:29 PM
halfcent did a great how to.
https://www.cobaltss.net/forums/show...ghlight=spring
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
n20saturn
Sep 30, 2015 12:26 AM
grampss
Sep 27, 2015 08:51 PM
