WARNING: Check your 'balt for brake line rub
I was just recently under my car doing an oil change when I noticed that my hard brake line going to the right front was out of its retainer. So I tried to put it into the retainer but it would not reach. I realized that the line is not bent properly and I believe that it is this way from factory because nobody has ever touched anything to do with brakes on my car. Because it is bent improperly and not in the retainer, it is rubbing on the frame of the car and also the bolt near the loop of the line. This is causing wear on the line. Here are pics of what the situation is.
CHECK YOUR CARS!!
CHECK YOUR CARS!!
This picture specifically looks like it's damaged
The line should be coming straight up out of that fitting. Yours appears to be bent right at the fitting. That would explain why it popped out of the clip. Check the other side to see what it looks like.
Already checked the other side and the bends are nice and straight. Not a loop. I was just not sure if the two are supposed to be different or it was actually damaged.
Just noticed this pic I had in my gallery. Apparently the brake line was in the retainer before. SO that means that someone must have tampered with it to cause it to come out of the retainer and change the bend on the line!
roth
Sep 26, 2015 12:16 PM
