Whats the diff between pro and sportlines
Actually I would expect the lower springs to be stiffer to keep them from hitting the bump stops (less wheel travel). The taller springs can be softer initially, and then progress to the same as the short springs at full jounce (they are both progressive, meaning as they compress they get stiffer in a non-linear manner - non-progressive springs add X pounds for each inch of travel, while progressive are X in the first inch, X+Y in the second, X+Y+Z in the third - well, hopefully that makes sense).
sportlines not only give the car a lower stance but the spring rates are off the charts and youd want a quality shock absorber to be able to handle that spring rate, and you will not like the ride and if you do your g/f or mom will hate it. lol, if u ever give your mom a ride.
woah.. conflicting info all over the place...Unless things have changed within the last 2 years the sports are specific and the pros are progressive. Going to make this a simple comparison. I've tried both on the same car. Sports are by far rougher but traditonally sit lower and help grip a TAD better. Pro's sit higher/softer but under load stiffen up. Kinda like the spring has a brain and knows if your mall crusing or blasting around an auto course. I personally found the sportlines to look better and handle better with the trade off of having baby shaken syndrome. Now Im drunk and too lazy to support my specific/progressive claims but I don't see how Eibach could have changed this formula. Someone chime in or Im going to have to do some reasearch.
they are both progressive, as far as spring rates, the prokit might be linear though, not sure, i doubt eibach will even release that info, someone would have to test it themselves. maybe one of the sponsors can call eibach and find out unless they have that info.
heres some good info on springs
http://www.hrsprings.com/site/about/manufacturing.html
ya i think i had the pros on my cavi
they where black and the drop wasnt very much
but man did the car handle
i had the kyb silver shocks, the pro kit, rear sway bar. over sidewalk ramps one tire would come off the ground cause it was so stiff
