Whats the diff between pro and sportlines
I had a Cavi. too! And yes when I dropped it I went with the Tein Tokico setup from Gravana, but so far nothing like that exists for the Cobalt. True if you want to get the Konis and cut your factories they will be better then stock. But droping the SS around an inch shouldn't pose a problem for the stock struts. Its only an inch!
Yeah the Pro Kit only drops the rear on the SS cars. Hell you may as well just leave the stock ones in the front and just do the rear, it'd save you some time and trouble.
Your gonna love em!
Your gonna love em!
Your gonna love em!
Your gonna love em!
The Pro-kit sits up higher, but has a stiffer spring rate, which allows for increased handling. The Sportlines are made for people wanting to slam their cars, allowing a softer spring rate, which gives a smoother ride, but decreased handling... however the spring rate is slightly higher than stock.
Think about it this way, all the springs do for you is gives you your ride height. The actual main handling aspects of the car come from your sway bars and shocks/struts. But if you do lower the car, giving it a lower center of gravity (which does slightly increase handling), you will NEED a better dampening strut/shock to get the full benefits of your springs and have a setup that works. Trust me, the stock GM struts on these cars can barely handle the spring rate of the stock springs, not to mention the spring rates of an aftermarket spring. Something like the Konis are the best way to go in this situation.
jsut got to your local auto parts store ask em for a spring compressor to rent and then use that for the fronts, and then just do the rears its not hard at all
because you lift the rear, and the springs pretty much are all the was depressed and you unbolt the bolts and then the rear suspension comes down and the springs come right out, theres a how to somewhere on here
https://www.cobaltss.net/forums/how-guide-43/how-install-springs-50477/
Last edited by Coblt ss super; Jun 7, 2007 at 08:45 AM. Reason: Automerged Doublepost
yeah autozone or napa should have some spring compressors or u can take the entire front setup shock spring mount to like big o tire or something like that a place that does alignments and they can do it manually for about 3-40 bucks and even compress the new spring on for u.
hold up, i'm sorry but sportlines are known for their higher spring rate than the prokit. the both help increase handling, sportlines give it a more aggressive stance as well as even better handling capabilities than the prokit. prokit have a lower spring rate and are not ment to drop it that much but still stiffer than stock. u got em backwards as far as spring rates and ride quality go.
The stance issue is relative to the car's owner, and has no effect in this conversation... that's a whole other topic.
The pro-kit however (given that a good set of dampeners is used with them) will provide better handling due to it's higher spring rate than the sportlines. Sportlines usually have a 350/135 rate, as the prokits have a 500/150 spring rate. Remember, this is typically, not exact specs. In fact, call up Eibach and get the rates from them, and you'll see what I mean. SO therefor, pro-kit > sportlines in handling characteristics.
I hope this cleared things up, and feel free to PM me or ask on here if you have any other comments or questions on this.
COMPLETELY wrong on the spring rate part. Here, let me explain myself a little further, and break down what you're saying.
There is a big difference between spring rates, and stiffness. Stiffness is usually explained through the feel of a car, in which the Sportlines would give a stiffer feel on a stock set of struts due to the dampening abilities of the struts being next to nothing on stock springs, which kills them on lowering springs. But due to that extra low drop, you'll feel a "stiffer" ride due to having 0 dampening on the car, and you'll feel every bump in the road.
Ok, both will increase handling over stock to some degree, just by increasing the spring rate over stock, and lowering the car's center of gravity (which has less effect than you think).
Just because the spring makes the car not sit as low, doesn't mean it has a lower spring rate. In all honesty, please do your research and you'll find that spring rate and ride height have NOTHING to do with each other. Look at 4x4 vehicles, EXTREMELY low spring rates, but hold up a 5,000+ lb. vehicle 2 feet in the air.
and why are you comparing a truck suspension to a car suspension? they are 2 seperate things. and being able to hold 5000+ lbs has to do with their chassis rigidity as well.
its plain and simple, sport line has a more agressive spring rate than the prokit. end of rant
Ok I have some bubble bursting to do. First off the spring rates WILL change depending on the car why would Eibach make the same spring rates for a Geo Metro that they do for a Dodge Ram Quad Cab? Come on man we may have been born at night but it wasn't last night! I just spent almost a half hour on Eibach web site and it says NOTHING about the spring rates being uniform for the Pro Kit or the Sportlines. Where did you get your info from? I think its seriously flawed.
Now HERE is what Eibach says about THIER springs that THEY make!
Pro Kit link...
http://eibach.com/cgi-bin/htmlos.exe...80455900031073
Sportline link...
I'm gonna contact Eibach directly and see if I can get the correct spring rates for the Pro Kit and the Sportlines.
burst my bubble never. cuz that really doesnt say much only the fact that the sportlines due state "race like handling" thats about it. we need a difinitive answer here. lol oh yeah your link for sportline dont work goes to prokit. heres the link
sportline
http://eibach.com/cgi-bin/htmlos.exe...68483500031073
sportline
sportline
sportline
Ok I just got off the phone with ABLE from Eibach and he says that the exact spring rates ARE NOT PUBLISHED AND CAN NOT BE GIVIN OUT.
BUT here's what he did say... That the Pro Kit is about 15% to 20% stiffer then stock where the Sportlines are 30% to 40% stiffer then stock. He said the Sportlines have a higher spring rate then the Pro Kit but he can not give out the exact #'s.
You just got an F on your homework Out1aw.
well heres what i got. i infact called eibach. i didnt exactly write down the spring rates so i might be off by a few % but that is roughly what they are. eibach sportline does have a higher spring rate than the prokit. damnit i hate it when i'm this good.
like ace ventura pet dic. says "can you feel it"
Spoke to adam at eibach, he states that the prokit offers a 10-20% spring rate over stock as the sportline offers a 25-35% over stock. Hence sportline having the higher spring rate.
score. yeah i was off on the percentage, i should have wrote it down. but damnit i love when I get an A, thats so hard to come by.
oh and Out1aw, if you would like to contact eibach themselves and inquire there number is 800-507-2338. thank you come again
Not your bubble you doof!
I'm agreeing with you!
It was ABLE not Adam.
You forgot please drive thru.
I love last minute homework. thats when i do good. i'm awsome at clutch time.
they can have mroe than 1 person working there. lets not call again and ask for the dudes name. haha.
and plus able adam they both start with an A, like my grade i got on my homework assignment. haha
