What's the rick...front struts
Working on install of springs.
I have left the top three nuts on in the engine bay. Removed the sway bar link. and loosened the two bottom nuts. Bolts are jammed in tight. Tried putting a jack under to support, but they are not coming free. I assume it's something I'm missing. Suggestions?
Thanks.
Thanks.
i assume your talking about the two bolts in the bottom of the strut if so just take a hammer and smack them out they are pressed in you won`t hurt the threads just leave the nut flush with the end of the bolt so you dont mar up the end of the threads when you hit it just don`t get to wild
