Wheel alignment? Camber kit?
Old Mar 27, 2012 | 01:48 PM
Play Pat's Avatar
Anyone have any problem with unstraighten tires after lowering springs? I have a camber kit but the guy said they probably wont be straight?!
Help please.
What else do I need or need to do?
Old Mar 27, 2012 | 02:18 PM
iToastie's Avatar
It's usually recommended to get an alignment after any suspension work is done.
If your wheel isn't straight, get one.
Old Mar 27, 2012 | 02:30 PM
Play Pat's Avatar
I will just. The place I went too. Said they worked on a VW and the wheels wouldn't become
Straight and you could tell. Just makes me sketched out.
Old Mar 27, 2012 | 02:38 PM
iToastie's Avatar
Others probably know more than I do about it, but with the camber kit it should help the tires to sit flush and flat against the pavement.
Check out other places to get an alignment.
Old Mar 27, 2012 | 02:53 PM
Play Pat's Avatar
That's what I been trying to do. I don't know who to talk on her. A lot of people in my city either want you to pay a lot of money and don't know how to do it. Don't know where to go.
Old Mar 27, 2012 | 03:26 PM
BLue NoTe's Avatar
Lower cobalts means front toe gets way out of alignment. Nothing happens to the rear.
Old Mar 27, 2012 | 04:33 PM
Play Pat's Avatar
Way out of alignment? I have eibach sportlines. So will my front tires be way out of alignment?
Old Mar 27, 2012 | 04:47 PM
BLue NoTe's Avatar
Your toe should be
Old Mar 27, 2012 | 04:57 PM
rcarr0327's Avatar
i put sportlines on my car and i didnt use the camber kit. they showed me the before and after alignnment sheets from the hunter rack and all of them were in the green except caster was off and they didnt fix it. idk what that is all about but get an alignment and u should be fine
Old Mar 27, 2012 | 05:06 PM
Validater's Avatar
Caster is not a problem. It doesn't cause wear. Only toe and camber cause wear. I'm lowered on cm springs and my camber was bang on. Only my toe changed as the tie rod angle changed so it made the tires both aim to the center. When it's supposed to be .1 of a degree aimed out away from the center.
Old Mar 27, 2012 | 05:30 PM
Play Pat's Avatar
So if the toe changed what did it do to the car??
Old Mar 27, 2012 | 06:09 PM
Validater's Avatar
It still went straight. But it will wear down your tires as it is no longer factory
Old Mar 27, 2012 | 08:04 PM
Play Pat's Avatar
anything I can do to fix it?
user 70823082's Avatar
No true, when I lowered my cobalt on springs and coilovers my rears cambered out unevenly also.
Old Mar 27, 2012 | 08:13 PM
Play Pat's Avatar
That Kind of makes me....sad hearing that. How bad does the tires wear down
Old Mar 27, 2012 | 08:14 PM
BLue NoTe's Avatar
I spoke for pedders. How low did you drop?
Just get an alignment, they are suppose to fix issues like that.
Old Mar 27, 2012 | 08:16 PM
Drop rate shouldn't make a difference. The fact that you're disassembling your rear suspension will in itself cause you're alignment to go bad, but I used SSC springs (~1.3F/~1.0R) Then Stance GR+ Coilovers (no wheel gap)
Play Pat's Avatar
I havent lowered yet. Im calling around trying to find people that are very knowledgeable about lowering and can give me a good price. I keep hearing people ask for $500-700 to do it
Old Mar 27, 2012 | 08:20 PM
Installing springs is a lot easier than it seems. Even if you're not suspension savvy you can still do it. I had no idea what I was getting myself into but it's literally pull front struts out, replace spring, replace strut. unbolt rear shocks (both sides) then place weight on the hub and pull springs out then replace with new ones. bolt everything up then you're good to go.
Old Mar 27, 2012 | 09:04 PM
Play Pat's Avatar
I would do it but I live in a dorm. My car sits on a street, wouldn't have anywhere to do it.
Old Mar 27, 2012 | 09:18 PM
Do you have any friends with a Jack and Jack towers?
Old Mar 27, 2012 | 10:15 PM
Play Pat's Avatar
An okay jack thats about it. Not a lot of tools.
Old Mar 28, 2012 | 07:54 AM
It'd be cheaper to buy the tools lol.
Old Mar 29, 2012 | 02:16 PM
Play Pat's Avatar
Yea me and my friend were talking about that. I found someone who can do it for 300. I wanna make sure its perfect. Wish I had my own personal garage.
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 04:49 PM
DANRICKARD
Oct 1, 2015 12:08 AM
