Wheel Bearings.
Old Nov 6, 2012 | 10:30 AM
yellow dragon's Avatar
Wheel Bearings.
So my driver side wheel bearing is going kaput. I was wondering what i need to do to fix it. I have heard you have to replace the whole hub, and I have heard you can just do the wheel bearing? Thoughts? Whats true/or better.
Old Nov 6, 2012 | 11:02 AM
emiller's Avatar
Replace the bearing/hub assembly.
Old Nov 6, 2012 | 11:18 AM
Thanks. Now to find the part number and start pricing **** out.
Old Nov 6, 2012 | 01:22 PM
Gelladuga69's Avatar
How do you know when it's bad? Small squeaks from a dead stop?
Old Nov 6, 2012 | 01:32 PM
1AJeremyD's Avatar
You would be looking for a Timken part number HA590086
Old Nov 6, 2012 | 01:45 PM
there is a rough grinding sound and vibration coming from the front end whenever I make a right turn.
Old Nov 6, 2012 | 01:50 PM
I hear a bit of howling here and there, also sometimes on the throttle i feel a bit of bouncing... hubs?
Old Nov 6, 2012 | 01:51 PM
1AJeremyD's Avatar
If its only during a turn it is most likely going to be an axle and not a wheel bearing. Do you feel a popping sensation as well?
Old Nov 6, 2012 | 01:53 PM
1AJeremyD's Avatar
Howling could possibly be from road noise as well as tire noise. Wheel bearings would be a constant thing regardless of dry pavement, wet, concrete roads or any other conditions. It would also not go away and then come back. Normally is starts during highway speeds(70-60mph) and then eventually continues down to just regular city driving (30-45).
Old Nov 6, 2012 | 02:02 PM
Nope no popping sensation, do you mean axle bearing? Or the axle itself?
Old Nov 6, 2012 | 02:06 PM
CannonBalt's Avatar
To know if it's a bad wheel bearing, It will be a solid "Hum", If you turn right and it stops it's the right bearing, If you turn left and it stops it's the left bearing. When you turn toward the bad hub you're transfering the weight away from the bad bearing, making it stop humming.
Old Nov 6, 2012 | 02:09 PM
I only hear it during a right turn at lower speeds.
Old Nov 6, 2012 | 02:13 PM
08baltSS's Avatar
Hey, sorry to thread jack, but what does it mean when you have a "popping" noise when making turns? I have the "popping" noise and kind of a grind both in the right front when turning.
Old Nov 6, 2012 | 02:14 PM
CannonBalt's Avatar
Then it's definitly not a wheel bearing.
That sounds like strut bearings..
Old Nov 6, 2012 | 02:15 PM
1AJeremyD's Avatar
Low speed noise during a turn would most likely be the axle itself or as stated above the strut. Your best bet would be to jack up the passenger side of the car, grab the tire, and try and rock the wheel back and forth and side to side. If there is excessive play, more than likely it is the bearing. If it appears to be fine, take the tire off and check the axle for a damaged boot or grease leaking. Normally it will leak grease before going bad but axles can still fail with grease still inside.
Old Nov 6, 2012 | 02:17 PM
CannonBalt's Avatar
Rocking the wheel back and forth wont show any play sometimes with bearings, I did that test and had no play, but it was still bad.
Old Nov 6, 2012 | 02:21 PM
1AJeremyD's Avatar
I figured it would be at least a place to start to do a self diagnosis of some sorts instead of throwing parts at a problem but ya I have run into the same issue where it didn't show anything and it was a noise. Then again I said excessive play which means hes been riding around with the problem for a few months not caring lol. Either way I hope what we have said helps him out a bit
Old Nov 6, 2012 | 02:26 PM
Me too thanks guys. Stay tuned I hope to get to this, this week depending on weather.
Old Nov 6, 2012 | 02:33 PM
08baltSS's Avatar
This is true, to a point. I have been riding on this problem for a while now, but i really do care and i feel bad, but i really don't have the time to have the problem looked at or fixed because i work 40-50 hours a week and am a full time college student.
Old Nov 6, 2012 | 03:19 PM
I have this too.. Only right turns though.
SORRY FOR THE THREAD JACK dragon, but I also think I have a wheel bearing problem which is why I'm here in the first place.
Old Mar 25, 2013 | 04:46 PM
06SS ALL DAY's Avatar
HA590086 that part number is for non sport suspension via rock auto
Old Mar 28, 2013 | 12:41 PM
574's Avatar
574
I'm looking on rock auto and how do you even choose? There are SO many
Old Mar 28, 2013 | 01:23 PM
EXsoccer1921's Avatar
by what matches your car lol. and you can get pairs off ebay for the price of one off rock auto
Old Mar 28, 2013 | 01:28 PM
574's Avatar
574
Alright, you do the whole think of choosing your car year make and model and after that there is still about 20 to choose from. I'll try ebay thanks
Old Mar 28, 2013 | 01:30 PM
yes but of those 20. there are still different hubs and descriptions. are you looking for front lsj hubs?
here's a pair
http://www.ebay.com/itm/Cobalt-HHR-G5-Ion-Front-Wheel-Bearing-Hub-Assembly-Set-Pair-22715554-/130601913307?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACobalt%7CSubmodel%3ASS&hash=item1e687b0bdb&vxp=mtr
here's a single
http://www.ebay.com/itm/Cobalt-HHR-G5-Ion-Wheel-Bearing-Hub-Front-22715554-NEW-/130601910987?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACobalt%7CSubmodel%3ASS&hash=item1e687b02cb&vxp=mtr
