Wheel Spacers Anyone..??
Old Apr 19, 2010 | 07:24 PM
averagewhiteboy's Avatar
Hey guys,
So, I'm contemplating getting some wheel spacers for my Cobalt.. Either get them for the front, or all around for stance.. Originally, I was figuring on going with only 3/16 spacers as to keep them narrow enough so that they don't effect my wheel studs, however I installed a set of 5/16 spacers on my Olds and have had no problems with them at all.. Plus, you can buy 5/16 ones locally, easily and cheaply.. Would you guys say to run 3 or 5 spacers..? I'd assume some will say to not run any, however I'd like to experiment with the flush wheel look.. I mean, if I don't end up liking them, I can pull them off easily.. I'd imagine they'd be ok with steering and such though, but if not, I can just pull them.. I'm lowered on Sportlines with stock FE3's for now, but I'm gonna get some FE5's or Koni Yellows soon..
Any opinions? Thanks!
Old Apr 19, 2010 | 07:30 PM
ecot3c inside's Avatar
I think it would look cool all the way around, not just the front that would look gay.
Old Apr 19, 2010 | 07:57 PM
I'd imagine. So I was figuring all around. I only run them on the rear on my Olds, but on a RWD, that's ok.. haha
Old Apr 19, 2010 | 10:15 PM
mperez's Avatar
i got 10mm spacers and studs on the front. just so i can use my rims check my photos.
Old Apr 20, 2010 | 06:39 AM
scottherbert's Avatar
If you want wheel spacers or wheel adapters, contact these guys in San Bernadino, CA -- http://www.motorsport-tech.com/ -- they'll make you custom CnC'd spacer or adapters cheaper than you can get them anywhere else. And they're quicker even making them than you can buy and get some 'standard' stuff delivered.
I bought custom 20mm adapters from them to mount my 285/30 x 18 Hoosier slicks. Very responsive, very nice, well machined.
Scott
Old Apr 20, 2010 | 09:55 AM
Omega_5's Avatar
I've been running 5/16" spacers with extended studs for a few months.... no issues at all, except that they aren't hubcentric, so you have to take your time when installing the wheel.
Note, though, that according to a few racer guys, it's recommended that you don't go larger than a 10mm spacers, as it puts additional load on the hub.
Old Apr 20, 2010 | 10:58 AM
What'd 10mm be in relation to 5/16?
Old Apr 20, 2010 | 01:19 PM
Omega_5's Avatar
5/16" (.3125") is 7.93mm.
The actual thickness of the spacer I'm using, though, is 7.75mm +/- .05mm
10mm is slightly thicker, at .3937".
Old Apr 20, 2010 | 01:25 PM
msfitoy's Avatar
what type of studs are you guys using?
Old Apr 20, 2010 | 01:38 PM
Omega_5's Avatar
I'm currently using Dorman... if I can get a hold of a set with the right dimensions, I'll be switching to ARP.
Old Apr 20, 2010 | 01:48 PM
mongorat427's Avatar
Get the hub centric ones for sure
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
