Wobble/vibration
Old Dec 19, 2012 | 11:51 PM
seeyaass's Avatar
Wobble/vibration
Okay so I'm getting a small vibration while driving at various speeds, high, low, etc.. It's annoying an makes the steering wheel shake side to side... But when press the brakes, especially hard from going fast there's a terrible vibration from the driver side wheel. Shakes throughout the whole care.. Feel it in the pedals, steering wheel vibrates uncontrillably, gonna try to look at it tomorrow if I have time. Any ideas?
Old Dec 20, 2012 | 02:14 AM
ijak's Avatar
personal experience, brake rotors warped.
shave it down at stealership or replace if it is the rotors.
Old Dec 20, 2012 | 10:57 AM
sLAsh's Avatar
Rotor
Old Dec 20, 2012 | 09:10 PM
seeyaass's Avatar
That's what I'm guessing also .. Been too cold to check Lately
Old Dec 20, 2012 | 09:15 PM
Cobra2255's Avatar
Funny you say that bc mine is doing the same! and I have a rattle in the steering now
Old Dec 21, 2012 | 06:53 AM
BLKLS's Avatar
Rotors won't make vibration unless your on the brakes, bent wheel maybe.
Old Dec 21, 2012 | 11:10 AM
Powell Race Parts's Avatar
This is the time of year to make sure you dont have a build up of snow and ice in the wheel itself that can cause vibration. Not saying thats your problem, but a qwik visit to the wand car wash can eliminate that. Dont powerwash the stick on weights off the wheel lol.
Old Dec 22, 2012 | 10:44 PM
seeyaass's Avatar
When u press the brakes you hear a rattle in the steering also? What about if ur stopped and u wiggle the steering wheel side to side? Do you hear the same rattle? Kinda under by your feet but in the engine bay?
Old Dec 22, 2012 | 10:45 PM
seeyaass's Avatar
I def considered that Powell but the vibration is far worse lol.
Old Dec 26, 2012 | 12:36 AM
seeyaass's Avatar
Bump cobra2255....
Old Dec 27, 2012 | 06:24 PM
06 SS/SC SLOBALT's Avatar
I had to replace my intermediate shaft in the steering column. That will fix the rattle going from side to side and when driving over bumps. But have your rotors and wheel checked for problems. Hopefully just need a new rotor
Old Dec 30, 2012 | 01:15 PM
seeyaass's Avatar
Thr intermediate shaft is the knuckle that slides onto the shaft from the steering rack?
Old Dec 30, 2012 | 02:03 PM
yea it slides through the firewall to the steering column from the rack heres the part off ebay but u can look up the part number on google to see where else u can get it
Chevy Cobalt Saturn ion Pontiac G5 Intermediate Steering Shaft | eBay
Old Jan 1, 2013 | 02:28 PM
seeyaass's Avatar
Okay cool was it hard to do?
Old Jan 1, 2013 | 05:14 PM
No it was real easy. Jack driver side of car up undo the bottom pin off of rack and then go in the car and undo the pin on top part that connects to the steering column. It's easy to but it's a pita getting underneath the steering wheel. When u install make sure u have someone hold the steering wheel to make sure u line up the splines correctly. Took about 15 minutes for a friend and i to install
Sent from my iPad using CobaltSS
Old Jan 2, 2013 | 01:30 AM
seeyaass's Avatar
As in pin you mean bolt? Cause slides onto the nipple on the rack and has a bolt that squeezes it onto the rack correct?
Old Jan 2, 2013 | 07:54 AM
Yea that's it.
Old Jan 3, 2013 | 07:02 AM
seeyaass's Avatar
Okay cool thanks a lot man.
seeyaass
Mar 19, 2014 10:47 PM
