Wobble?
Old Mar 14, 2014 | 08:28 PM
seeyaass's Avatar
Wobble?
What's up guys. I recently did a clutch job in my car and when I put it back together I forgot to tighten the axle nut on the drivers side axle... I drive for 30 miles and realized it was loose and tightened it. Now if I drive between 70-80mph on the highway I'm getting a wobble/vibration. I can't tell if it's the axle cause it's not making noise or have any play in it...
Anyone think I could have damaged it which is causing this wobble/vibration?
I don't wanna go but one and waste 170$ if it's not it. Under 65mph you can't feel it at all.
Old Mar 14, 2014 | 08:31 PM
dannysauer's Avatar
Don't think that it's the axle I would make sure everything is tight u may have not torqued everything down also make sure the wheel is tight
Old Mar 14, 2014 | 08:47 PM
seeyaass's Avatar
I checked the wheels.. I'm pretty sure everything else is tight. It's only above ~65mph. Only reason why I'm guessing axle is cause I drove it with it loose and it could of been flopping around when I was driving damaging the cv?
Old Mar 14, 2014 | 08:57 PM
dannysauer's Avatar
Well if u have a buddy with a tc just swap and test before spending that money
Old Mar 14, 2014 | 09:07 PM
seeyaass's Avatar
Yea I don't think he would though lol.
Old Mar 14, 2014 | 09:08 PM
chris88z24's Avatar
100% ruined CV joint.
Old Mar 14, 2014 | 09:33 PM
seeyaass's Avatar
Even though it don't make any noise? Or doesent feel damaged?
Old Mar 14, 2014 | 09:42 PM
chris88z24's Avatar
Probably over extended the joint.
Old Mar 16, 2014 | 08:24 PM
seeyaass's Avatar
So I changed the axle.. Didn't fix anything I'm gonna go over the bolts and see if I missed anything!
Old Mar 17, 2014 | 01:07 AM
seeyaass's Avatar
It starts at above 65, it does not go away if I turn the wheel, you feel it in your feet barely in the wheel, and sometimes if your on a flatspot it will go away but immediately come back, don't feel it when you press the brakes in the pedal or anything. It's driving me crazy
Old Mar 17, 2014 | 11:49 AM
seeyaass's Avatar
Bump anybody?
Old Mar 17, 2014 | 11:55 PM
chris88z24's Avatar
Strange how it wasn't the axle.
Old Mar 18, 2014 | 12:01 AM
steveobed's Avatar
Tire balance could be unrelated to the clutch job
Old Mar 18, 2014 | 12:28 PM
seeyaass's Avatar
This thing got me stumped bro!
I don't know what else to look for
Old Mar 18, 2014 | 12:31 PM
Haven07's Avatar
Try jacking up the front of your car and check the wheel bearing?
Old Mar 18, 2014 | 12:37 PM
seeyaass's Avatar
I needed a control arm bushing in the driver side, changed that it went away a little bit but it's still there. Under wot you can feel it more
Wheel bearings seem fine to me. That I can tell, there's no play in them.
Old Mar 19, 2014 | 10:47 PM
seeyaass's Avatar
Ended up being dirt in my rear wheels.... I feel dumb lol. Thanks for everyones help!
seeyaass
Sep 5, 2012 12:33 PM
Twoozofjuice
Mar 12, 2012 12:18 PM
NexTnmE
Jun 26, 2008 10:33 PM
Bob T
Oct 4, 2005 08:29 PM
