YYZ springs
John, With the new springs do we need new rack spacers? I still have pedders springs in with those rack spacers.
It does reduce rotating mass, but that has little effect on the ride quality and a marginal effect on acceleration (talking 10ths of a second difference maybe). For a better ride you either need more travel or more tire sidewall to absorb the impact force
This, very little effect, but it should ride better.
Ok, I know my M52 is 22 lbs and PF01 is 18.5 lbs. If I get PF01 rims on the car then it would be a huge jump 14 lbs off for set of 4 rims on the car. I know it will improve rotating mass, braking, and turning.
I am so lost on the noise; its evident that its the dead coils, we got two solutions going, but I dont hear the noise on my car. Must be deaf I suppose. lol
I can send you fix to try. if you wish or direct you to where it can be obtained ups get cranky with jiggle cans across the border lol email me please
It's random for me John, I'll try a couple different tubing options I have access to via my work. Also Colorado roads blow donkey dick the civil engineers out here live in a dream world that isn't exposed to the weather we have. I can't comment on how they compare to the roads up by you, haven't been to Canada for a good 10years.
Maybe give them a shot. Worked on my springs to quiet down coil slap from the dead coils.
YYZ Spring Sleeve CED4454
Damn I hadn't thought about putting extra holes in them.
Wouldn't want getting water trapped in there.
These
I am using a different spray on approach right now. I am not a fan of the sleeve solution although its an immediate fix, but as they are a spiral coil they hardly need drain holes;they are only about an inch wide in a spiral wrap.
Some of the HSD coil overs come with a sprayed on cushioning material. HSD make private label coil overs as well, like Stance for example. Some coils are beehive shaped springs to avoid dead coils touching, but I am not sure how effective they are.
